Old 08-05-2014, 07:54 PM   #1
Coachwork: -
Chassis: -
Engine: -
European engines and Transmissions
Hi all,
I wonder if there is a driveline mechanic/engineer on this forum, that has some experience with standards.
I understand that about everything is standardized and to a certain extend can be mixed and matched.
SAE/ISO would be some standards that drivetrains would adhere to.
So the bellhousing patterns should be standardized and then these to transmissions.....
I wonder if anybody has any experience to match up a Cummins or International/Navistar to ZF-Ecosplit trans??
Any Euro members here? Or someone from South America?
I drove these a while back (early 90s) in their Ecosplit-16 version from 360 hp to 520hp and am in love with these transmissions!
My plan is to get one installed in "my bus" (when ever that happens) - this would give me 16 speeds and I end up with the perfect gear for about anything!
16 gears is certainly overkill, but if you get a used trans it doesn't really matter anymore, does it?
The smallest Ecosplit-16 will EASILY take any torque any of the bus engines can dish out......
My further plans include a change to complete air-suspension, a possible tag axle and hydro-drive on the tag and front axles for those sticky situations on far off dirt roads. The air-suspension will be built in a way so I can get a serious lift to get over rough stretches - to the extend the driveline angles will allow form the RE.....
The 16-speed would give me from a serious crawl speed everything to a ultra highway OD - (counting on the splitter, there are 2 crawlers in the trans, 2 reverse + 2x(splitter)2x4 gears)
However before starting to look for a trans, I need to find out if I am right about the standardization issues and if it is economically feasible to go this way....
Cheers,
thjakits
thjakits is offline   Reply With Quote
EEaT or Euro Engines and Transmissions! thjakits Conversion General Discussions 3 09-05-2014 06:16 PM
GM Engines CAMO-MONSTER Everything Else | General Skoolie Discussions 18 08-17-2009 09:06 PM
who knows their allison transmissions??? lapeer20m Conversion General Discussions 8 12-14-2007 07:27 PM
Which engines should I look for? Which ones to pass on? Train-train Mechanical and Drivetrains 8 06-24-2007 10:40 PM
Changing Engines Jarlaxle Conversion General Discussions 4 06-12-2006 05:29 PM
