Re: 95 blue bird issue
Sounds as if you may have a loose connection from your battery to the starter solenoid or at the switch solenoid, located in the box outside the drivers window, or in the back of your heater, fan and defroster switch panel. Not sure what the proper name is, but it is round and has large wires going to a least two terminals. It also makes a click sound when turning the start key from off to on.
