Old 02-11-2014, 08:32 AM   #1
The Painted Lady's Avatar
FE vs. RE - pros and cons...
I would like some input on engines. Front engines vs. rear engines.
(Eg.) Pros and Cons. Does one require more maintenance than the other?
The Painted Lady is offline   Reply With Quote
Old 02-11-2014, 10:13 AM   #2
opus's Avatar
Chassis: All-American R/E
Re: FE vs. RE - pros and cons...
RE ride much better and are considerably quieter.
[edit]
Oops, that doesnt seem to be the question you asked. An engine is an engine, front or rear, doesnt matter.
Old 02-11-2014, 10:15 AM   #3
in relation to FE vs RE in a flat nose bus
FE is a lot louder and has a "dog house" to crawl over
RE is a metric crap ton quieter
FE has a back door, which we use all the time (emergency exit for bedroom and all around door for exit)
RE no back door
RE easier to remove and I will guess with what I have seen probably easier to work on
Old 02-11-2014, 02:51 PM   #4
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
RE has more usable space underneath,no driveshaft or exhaust system
In a Blue Bird RE has larger entrance steps.
RE doesn't have a doghouse in the way to get to the driver seat.
somewhereinusa is online now   Reply With Quote
Old 02-11-2014, 03:57 PM   #5
Chassis: B3800 Short bus
Rated Cap: 36
Do note that front engine dog nose buses do not always have a dog house. If they do it is much smaller than a FE flat nose dog house.
Old 02-11-2014, 05:24 PM   #6
Steve's Avatar
My current main bus is an RE and although much quieter for the driver while going down the road I would run my old FE bus sometimes for heat or power and you wouldn't want to try to get some rest with the RE rumbling underneath you. I also think there is much less access to the RE engine, but that depends how the engine cradle swings away.
For sure the extra space underneath a RE because there is no driveshaft tunnel is a plus.
Old 02-11-2014, 09:40 PM   #7
sometimes its harder to find a RE bus, at least in my neck of the woods, if I was to build another bus, I would go with a RE
6.0L / 6.3 / 7.3 - anyone have pros or cons to share? wirelessguyNY Ford Drivetrain 3 12-20-2014 02:14 AM
PROS/CONS of a Roof rack? GreyEagle Everything Else | General Skoolie Discussions 7 03-04-2013 08:03 PM
Window choice pros and cons bapos Conversion General Discussions 19 07-24-2012 11:53 AM
Pros / Cons Of Different Bus Platforms? bus-bro Mechanical and Drivetrains 5 12-19-2011 09:03 PM
Pros/Cons of holding tanks inside the bus elkoskoolie Plumbing, Water and Waste 0 06-13-2009 08:46 AM
