Old 04-09-2014, 03:42 PM   #1
Sara's Avatar
The Most Insane Truck Ever Built
Alright... so here it is: The most insane truck ever built. The subject doesn't really do this article justice. How come my dad didn't build this for me??!
http://www.wired.com/2014/04/worlds-biggest-rv/
Sara is offline   Reply With Quote
Old 04-09-2014, 04:41 PM   #2
JakeC's Avatar
Re: The Most Insane Truck Ever Built
Dang!!!! The amount of tech in there is mind boggling. I think a unimog in and of itself is amazing! That would be even better than a vanagon
Brutus
Old 04-09-2014, 05:20 PM   #3
Sara's Avatar
It's pretty awesome... but I would choose the Vanagon for undisclosed reasons.
Old 04-10-2014, 08:35 AM   #4
Sorry, not impressed. A lot of Skoolies are more practical for traveling and living, and almost as electronically capable. Even though I see a little bit of my own mad scientist in this guy, we are not twins separated at birth.
First, the trailer/living unit.
- You can't use the living or working space while driving, the trailer has to be deployed.
- It takes set-up time - if you notice, it is a high-low design. You have to slide the top section up ("Roof Raise!") before you can swing out the kitchen and bathroom modules at the rear. With a Skoolie or RV, you just walk back into the living area, even while someone else is driving.
- Some of our skoolie kitchens are better prepared to cook gourmet meals than his swing-out kitchenette.
- I'm guessing that the trailer upper section walls aren't that thick to allow the slide up, hence poor insulation.
- All his special materials for extreme heat and cold will likely not be repairable at the local truck shop after any untoward event.
- I think his best-case estimate of 2000 highway miles on 170 gallons of diesel isn't going to hold up when he opens the throttle on that heavy wind-catcher.
Next, the comms and electronics, which appear to be the "Gee-Whiz" factor.
- He threw every technology from short wave to satellite into the unit. It looks like he just checked every box on a shopping list, instead of having a real plan.
- He is connecting all the terrestrial comms to what appear to be military-inspired "one size fits none" broadband antenna designs, which work equally poorly at all frequencies. These are necessary for the military, who must be able to operate anywhere, any time without tech support on the line. Hams, business and Public Safety would instead use antennas optimized for the frequencies they use.
- The comms antennas are down low on the cowl, blocked by the vehicle in most directions
- The direction finder radome is too small to have doppler-effect dipoles spaced apart enough to work most efficiently at VHF. Either this is a UHF/microwave unit, or a military unit which uses uber-computer processing power to make up for more subtle doppler information. The article mentions using it to find locator beacons. I expect it is a single-purpose unit designed for a particular beacon type.
- All his comms appear on a "glass cockpit" control wall. They appear to be set up to be managed by a single operator. (California Highway Patrol several years ago was looking at a touch-screen system to manage 4 single-band radios in the trunk, I don't know if they deployed that system or not.) If the vehicle will be loaned out for research, you usually would have a couple of operators working different "nets." They would need "elbow room."
I will give him that FLIR (Forward-Looking Infra-Red) cameras are cool. So are inflatable masts, but they are not that rare. See if a local TV station is scrapping a news van. You can buy small scout drones for a couple hundred bucks. You can buy personal satellite beacons that pair with smart phones for text from anywhere for another couple hundred bucks. You can (as he did) buy a satellite phone handset if you feel you need it, and can get a car kit to use it as a console. You can get satellite internet with an automatic dish for a thousand or two. You can perform shortwave ALE (Automatic Link Establishment) with a standard PC-controllable radio and some computer software, without needing a NATO radio.
Come on, Skoolies, we can (and do) do better than that for much, much less!
Edit: Skoolie Jerry Campbell posted a video of his campsite taken from his drone at Nomadicista.
You can see the more efficient short-wave antennas on the roof of his Crown.
Old 04-10-2014, 10:25 AM   #5
JakeC's Avatar
Meh, I get what all you are saying, but I think it's obvious he has money to burn and gives no shits. Sounds like there are things he could have done differently, and I agree with some of the things you pointed out, but the rig itself is still incredible, and I bet it will serve his purposes just fine. I suspect that this project was more just something for him to play with, show off a bit, if you will. Maybe it's just his prototype, to see what he wants to change for his next one
Well, they do have a kitchen and a bed. What more do you need?!
Brutus
Old 04-10-2014, 11:30 AM   #6
Chassis: B3800 Short bus
Rated Cap: 36
I was thinking the same thing. He's expecting ~11-12mpg in that thing. Seems optimistic considering the wheel and wind resistance. Perhaps it's light enough, though.
Old 06-13-2014, 04:36 AM   #7
Year: 85
Coachwork: Ward
Chassis: G.M.C. 6000 series
Engine: 366 G.M.
Rated Cap: 60
He's got bucks to burn, I find his equipment a bit over the top.
Russell is offline   Reply With Quote
Old 06-13-2014, 09:54 AM   #8
Chassis: All Canadian FE
If I had shits to give I still wouldn't build anything that complex. I can barely figure out my smart phone some days lol
fly the coop
Fig. to escape; to get out or get away. (Alludes to a chicken escaping from a chicken coop.) I couldn't stand the party, so I flew the coop. The prisoner flew the coop at the first opportunity.
www.flythecoop.ca
pictureLOVE is offline   Reply With Quote
Old 06-13-2014, 10:17 AM   #9
wmkbailey's Avatar
Engine: 3126
X2
William
https://thejourneyvisvi.com/
My Conversion Thread:
viewtopic.php?f=9&t=464989
Old 06-13-2014, 04:10 PM   #10
Sara's Avatar
If I had the money to buy something that awesome, I would also employ someone to run it for me. Hahaha. A chauffeur, of sorts. I don't think I'd be parallel-parking that thing myself. I guess you could just "monster-truck" over the other cars, though. Hahaha. On second thought, I do believe I will TRY parallel-parking...
Old 06-13-2014, 04:59 PM   #11
If I had that kind of money to burn (and some shits to give) I'd buy an island and start a skoolie resort... LOL
fly the coop
www.flythecoop.ca
Old 06-13-2014, 06:04 PM   #12
Sara's Avatar
Wait. Thats a better idea. I'm down. Let's make this happen.
Old 06-13-2014, 07:50 PM   #13
Let's google this guy's gmail and ask him to put up the funds. lol
fly the coop
www.flythecoop.ca
Old 06-14-2014, 01:03 AM   #14
I thought DasMel was the only one planning on driving her Skoolie to an island . . .
The biggest problem I see is that he is spending all his time on the opposite coast building this "gift" for his daughter, losing time that he can never recover, rather than spending time with her . . . .
Old 06-15-2014, 10:41 AM   #15
Sara's Avatar
I feel like it could work. Hey... you don't know until you ask, right?
I always wanted to live on a houseboat somewhere awesome. Maybe I could make my skoolie amphibious...? It's like a houseboat, but more awesome because if I don't like living on the water, I can move to land. I have to figure this out. Practical? MAYBE. Haha.
Old 06-15-2014, 11:29 AM   #16
Scooternj's Avatar
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
There's always this-
Besides, if you've got a pusher, the intake should be high enough. Just need to mod the exhaust so you're not sucking in water.
We got lucky when we shut down after we blew the front pumpkin while awaiting recovery. The angle prevented the muddy water from getting sucked into the block.
Hey! That's not an RV, that's a school bus.
Well thank you for noticing, Captain Obvious
Captain Obvious on deviantArt
Scooternj is offline   Reply With Quote
Old 06-16-2014, 08:49 AM   #17
Sara's Avatar
Wowsers. Yep. That's exactly what I would be going for. Why stop with an amphicar? Why not an Amphibusbadassmobile?!
Old 06-16-2014, 11:45 AM   #18
Scooternj's Avatar
Engine: T444E/AT545
Rated Cap: 75
Some one find me a DUKW (pronounced "duck") hull to put my bus on.
Old 06-16-2014, 02:05 PM   #19
Sara's Avatar
I shall move this thread to the "Classifieds / Wish List" section. Haha.
Built-in toddler bus seats skrapgiarc Classifieds | Buy, Sell, Swap 11 09-09-2015 03:37 PM
Has anyone actually built their own waste H2O tank? TygerCub Conversion General Discussions 2 06-07-2012 11:24 PM
My new Diamond built e350 gopack444 Short-Bus Conversion Projects 30 04-23-2011 07:57 AM
Has anyone built or thought about a safe for their bus? crazycal Conversion General Discussions 7 05-29-2010 05:40 AM
Towing a 4x4 truck (small truck) 4 down Abbott Everything Else | General Skoolie Discussions 13 12-31-2009 02:05 AM
