Old 12-09-2012, 08:53 AM   #1
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
How to link pictures from Photobucket
You are not posting your picture onto the skoolie web site, just the address of where it is on photobucket.
Other picture posting sites are similar.
If you are using the old version of PB, this is what your site will look like
When you do the left click it copies the web location of your picture to your clip board.When you are ready to insert the picture into your text,
simply hit ctrl+V. That will paste the photo address along with the IMG tags that tells the skoolie site to insert the web address of a picture.
This is what your post will look like.
When you are writing your post, you can see what it will like by using the preview button.
If you are using the new version of Photobucket it is similar but just looks a little different. It just takes one more step.
This is the first step.
Then this.
The post to skoolie is the same.
Dick
Old 12-09-2012, 09:59 AM   #2
SeanF's Avatar
Chassis: IHC
Engine: Dt360
Rated Cap: 19
Re: How to link pictures from Photobucket
Nice write-up. Thanks for taking the time.
Bus conversion/info here
SeanF is offline   Reply With Quote
Old 12-09-2012, 09:49 PM   #3
Thanks, that makes it easier to use the new PB. Jack
Old 01-24-2013, 12:14 PM   #4
thommassey's Avatar
Year: 1986
Chassis: All American RE
Engine: 3208TA Cat 250HP
Ditto...
TUMBLEWEED (AKA Rufus) build:
viewtopic.php?f=9&t=11121
PICTURES : https://s1338.beta.photobucket.com/user/ ... M-HP/Rufus
thommassey is offline   Reply With Quote
Old 02-05-2013, 04:31 PM   #5
Chassis: AARE
The URL
s1310.beta.photobucket.com
you posted is the Photobucket URL from the top of the page. When you left click the photo "IMG code" it will automatically copy what you want to your clipboard.
It should look something like this, only it will have a square bracket on each end. One of these [ at the front and one of these ] at the back.
Just do a paste where you want the picture to appear, you don't have to worry about the brackets.I left them off so it wouldn't show a picture.
img]http://i69.photobucket.com/albums/i79/somewhereinusa/web3150.jpg[/img
Hope this helps.
Dick
Old 02-05-2013, 05:23 PM   #6
Chassis: AARE
You have to put the image tags inside of square brackets
[img]before
and
[/img]after
If you want to do it differently than the tutorial, you can get the url of the picture by having the full size picture open, this seems to be where you are getting
your address. You do a ctrl c (copy) of the address from the command line of that page. In the post a reply box (where I am typing right now)
There is a box labeled "Img" click on it and it will insert the image tags with your cursor in the middle. Simply hit ctrl p (paste) and it will put the url in the right place
with the proper tags. You can see if all is well by using the preview button below. I always preview my posts, so make sure everything works like I wanted and to make
sure I said what I thought I said.
Cheers,
Dick
Old 11-15-2014, 08:53 PM   #7
go00nascar's Avatar
Engine: 5.9 Cmmins
Rated Cap: 71
thanks
go00nascar is offline   Reply With Quote
Linking to your Photobucket pictures in messages. roach711 Conversion Tutorials and How-to's 0 02-25-2013 09:57 PM
The new Photobucket Accordion Everything Else | General Skoolie Discussions 3 01-08-2013 11:49 AM
Photobucket Question lornaschinske Everything Else | General Skoolie Discussions 3 02-14-2010 11:16 PM
Store link nyrockingchairs Forum Admin | Account Help | Suggestion Box 4 10-30-2007 06:38 AM
Fix my link? Joreth Conversion General Discussions 2 03-02-2005 06:57 PM
