Old 03-05-2014, 06:46 PM   #1
Chassis: Freight-shaker (Freightliner)
Engine: Cat 3126b 250 HP
Rated Cap: Only 1 seat
Electrical System Switch
Hey guys n gals. I want to set up my dc to ac system on my bus. I am going through and getting an inventory for my project and ideas for things I need. However, I don't know what I need to be able to change the charging system on it automatically. Meaning, I want to be able to use shore power, or solar, or the alternator to charge my house batteries without having to manually hit a switch so I don't 1.- burn up my alternator and kill my system, or 2.-backfeed the grid and kill my system, or 3.- burn up my batteries and kill my system!
So can anyone help?
TIA
-Doc
Docsgsxr is offline   Reply With Quote
Old 03-05-2014, 07:40 PM   #2
Chassis: TC2000 FE
Engine: 190hp 5.9 Cummins
Re: Electrical System Switch
Budget?
Changing things manually is the cheapest rout.
This cost $1000
http://sterling-power-usa.com/12volt400 ... arger.aspx
Nat
Old 03-07-2014, 07:31 PM   #3
Not exactly what I was meaning.
No budget.
Just want a 3 way switch to control the charging systems so they don't compete. I want to make it so the alternator is in use first, then shore power, then solar if the other two aren't engaged to charge the house batteries.
Can't seem to find something like that on the forums.
-Doc
Old 03-21-2014, 02:01 PM   #4
enthe0gen's Avatar
Chassis: 3800
Engine: IH DT466e
No budget.
-Doc
You're looking for a power transfer switch (PTS). A PTS will automatically cut over from one power source to another, which i believe it what you're looking to do. A simple google search for "3 way power transfer switch" came up with this product, which might be exactly what you need: http://www.theinverterstore.com/tran...enerators.html. I dont personally have a need for a 3-way switch, but i use this 2-way switch to swap between shore and generator power:http://www.amazon.com/Go-Power-TS-50...ransfer+switch.
Pretty easy to wire up too (provided you have a basic understanding of household wiring). Hope this helps.
"In the universe, either we are alone or we are not. Either possibility is terrifying." - Arthur C. Clark
enthe0gen is offline   Reply With Quote
Old 03-21-2014, 03:04 PM   #5
Chassis: TE2000 FE
Engine: 5.9L Cummins
http://www.amazon.com/s/?ie=UTF8&key...l_8ua697pnso_b
these are all marine rated
Chuck
Old 03-21-2014, 03:07 PM   #6
Chassis: TE2000 FE
Or there is this type
Chuck
Old 03-30-2014, 11:17 AM   #7
enthe0gen
That would be perfect, but that is used to switch power to your unit, meaning, power from batteries, or power from shore, or power from a generator go into this switch, then into your system.
I'm looking for something that will be put inline before the batteries. So it will automatically select the charging system to the batteries.
cschlessman
This would work, if it had a 3 way setting and were autoimatic, for 3 independent charging systems. These show 1, or 2, or 1+2. I want one that would go from 1, to 2, to 3 and not be manual. I could do a manual style like that but would have to have 2 switches. 1 controlling 2 systems and the second controlling the 3rd.
Old 03-30-2014, 11:32 PM   #8
Chassis: Saf-T-Liner MVP ER
Engine: CAT 3126b Rotella-Chugger
http://www.westmarine.com/blue-sea-syst ... 73_008_503
This is what you're looking for. The picture shows a 2-way but look at the items listed below and there are 3 way. It is more expensive than a switch should be in my opinion, but it is what you need and @ 30 amps.
It isn't automatic but by "no budget" i assume you mean no $ to spend? In that case you won't be able to afford a manual.
porkchopsandwiches is offline   Reply With Quote
Old 03-31-2014, 08:31 AM   #9
Originally Posted by porkchopsandwiches
http://www.westmarine.com/blue-sea-systems--ac-rotary-source-selector-switches--P009_273_008_503
Exactly opposite, I mean I am not concerned if it were to cost 300 bucks or 10.
So I am to assume that an automatic transfer switch can be used inline before the batteries as well as after?? The ones I am finding are for powering your "house" if one type of power goes out it diverts to the next. Does it work the exact same way with charging the "house" batteries?
Electrical system - does this schematic look right? Anomalous Electrical, Charging and Solar 21 12-06-2016 01:10 PM
Just starting: electrical system question BelltownBikes Electrical, Charging and Solar 10 03-18-2013 03:36 PM
interlock panel on electrical system adamanderr Conversion General Discussions 0 04-07-2008 06:59 PM
Electrical System Setup jnizzle Conversion General Discussions 9 01-30-2008 12:00 PM
mystery switch westport_wayne Everything Else | General Skoolie Discussions 4 08-12-2006 11:23 PM
