Old 04-16-2014, 10:03 AM   #1
Engine: Big Block
Power inverters and electrical questions
I've reached the electrical point in my skoolie conversion, I am ready to start purchasing some much needed materials, but am still a little confused on the electrical set up that I will need. I figure that I will have 5 outlets, for small lamps, a computer, an internet hookup, a fridge/freezer (I know that I can run it a few hours a day and keep my perishables good to go and oh yeah its a mini fridge) a juicer that I use a couple times a day and maybe one or two other small items needed very little day to day. After some research I figure I will need 2000 to 3000 watt inverter, but what brand is best? and should i go higher on wattage or split it up and get several smaller watt inverters? Also, cable size will vary right? I think I will have three 12v batteries, a few solar panels as time goes on, and a hookup for rv camping and or from a house... As you can see I am little confused but have a fundamental understanding... Anyone with information would help me greatly. Thank you : )
MissJaneStrummor is offline   Reply With Quote
Old 04-16-2014, 01:34 PM   #2
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
Re: Power inverters and electrical questions
Start reading here
http://handybobsolar.wordpress.com/
Stu & Filo. T is offline   Reply With Quote
Power inverters and their uses drchefscott Skoolie Conversion Projects 17 04-16-2009 08:46 AM
Harbor freight power inverters lapeer20m Conversion General Discussions 0 09-20-2007 10:15 PM
Cheap Power Inverters the_experience03 Conversion General Discussions 11 03-10-2006 07:18 PM
cheap power inverters batchlor BusMan Everything Else | General Skoolie Discussions 2 04-06-2004 05:02 PM
Power Inverters - which makes more sense? bus.driver Everything Else | General Skoolie Discussions 2 02-24-2004 11:01 AM
