Old 04-21-2014, 09:48 AM   #1
Cheap AC= Temporary
Thought that some might could use this. Seems strait forward enough.
http://videos.komando.com/watch/5464/vi ... e-solution
Former owner of a 1969 F600 Skoolie.
1998 Ford B700 Thomas body 65 passenger. 5.9 Cummins 12 valve with MT643 Transmission 123,000 miles.
Versatile is offline   Reply With Quote
Old 04-21-2014, 11:12 AM   #2
Year: 1979
Chassis: IHC
Engine: 366
Rated Cap: 48
Re: Cheap AC= Temporary
Cool
[snicker,snicker,snort]
alwaysFlOoReD is offline   Reply With Quote
Old 06-02-2014, 02:47 PM   #3
Chassis: TC2000 FE
Engine: 190hp 5.9 Cummins
You would be better off pumping cool lake water through your heater cores with the fans on high.
The freezer they are using to freeze the ice is adding heat to the house. It's not a usable, or logical system.
Nat
Old 06-02-2014, 06:19 PM   #4
Chassis: International 1753
Engine: 6.9 International
Freezer could have been out in the garage. It's kind of neat but I've seen things like this done before with the Styrofoam coolers that you can buy at the carryout and a couple bags of ice.
My build: The Silver Bullet https://www.skoolie.net/forums/f11/p...llet-9266.html
Booyah45828 is offline   Reply With Quote
Old 06-07-2014, 09:37 PM   #5
bapos's Avatar
Engine: DT466E/MD3060
Hmmm
Unless I missed something in HVAC design class I don't see how this controls humidity in any way? Nice redneck ac unit but as for really conditioning the air…… I don't think so
Old 07-31-2015, 04:41 PM   #6
I have done this to cool my car when my ac compressor broke, it works for the first 10 minutes till the ice freezes, a better design is to use a tranny cooler with a fan and pump the ice water through the cooler with a bilge pump, or a heater core.
THE-LAZOS is offline   Reply With Quote
Old 08-24-2015, 07:06 AM   #7
perspective
Originally Posted by bapos View Post
Hmmm
Seriously the frozen milk jug IS a heat exchanger and I guarantee that there will be a puddle of condensation at the bottom of that in no time flat, that is if there is any measurable amount of humidity in the air.
If you were to take that base design put the holes on the bottom about .5 inch off the bottom of the liner (which I think to be completely moot as you are blowing room air through it with out a cycle timer or thermostat). Now put a grate on top of the PVC pipes. then put your icy heat absorber (frozen milk jug in the video) on top of that. If you wanted to increase the efficiency of heat transfer use frozen water bottles and arrange them in a hexagonal pattern for more surface area and air throughput. Also I would suggest a large computer fan instead of that beast.
This type of thing seems like it would be best served for parties and weekend trips as that will quickly be a lot of work to stay slightly cooler.
CaptainInsaneo is offline   Reply With Quote
BB Bus for cheap frank-id Classifieds | Buy, Sell, Swap 0 08-09-2014 11:17 AM
Cheap 16' Awning timbuk Classifieds | Buy, Sell, Swap 1 12-06-2008 05:49 AM
Where to get cheap batteries? phillbus914 Electrical, Charging and Solar 3 11-29-2008 10:22 PM
55 gmc on ebay - Cheap! captainkf Everything Else | General Skoolie Discussions 0 01-15-2007 06:31 PM
Temporary Insurance? glock17 Titles, Insurance, Registration and Money Matters 1 03-12-2005 11:26 PM
