Old 07-11-2014, 08:24 PM   #1
Year: 1981
Chassis: All American FE
Engine: Cummins 555 9.1 L diesel
Tire size and brand question: Move from 12R to 11R?
Hi all,
I'm in need of a new set of tires (my wallet just screamed a little). I only run about 3,000 miles a year, most is highway but some is on gravel roads.
I'm running very old Goodyear radials in front (steers) and a mix of four recaps in the rear (drive). They are all size 12R 22.5.
My first question is about moving to an 11R from the 12R. I'm thinking to keep the 12R in front as Lucinda is a transit style and I like the additional load rating. In the rear, though, I've had some dicey clearance in my wheel wells when fully loaded near my GVWR. It's not the wheel well itself, as there is actually plenty of vertical clearance, it's the side of the wheel well or outer wall of the bus that comes down within an inch or so of the tire. It would be fine if the tire were inset about an inch further, but alas it is not.
Moving to the 11R makes the tire a little cheaper, and a lot more common on the road. It increases the tire revs per mile, which I think then also increases my rpm for the same speed. I don't really know how much, though, and I've also read that smaller tires will increase speed (why? Easier to spin?). My old dealer thinks I should stick with the 12s, that I'll lose speed, won't gain much clearance, and will increase the rpm wear on the engine. The local tire shop says the 11R is what all the fleets are running here now, and says that I will gain some clearance, and will hardly notice a speed difference.
Past the size question, I'm thinking of Firestone steers (City Transport Radials or FS560) or Daytons, which is lower in the Bridgestone/Firestone/Dayton line (Radial Metro steers, Drive Radial drives). Any thoughts on these tires? Quality/Value? I also looked at Hercules L-303 drives, but with a 50 mph rating I thought the Daytons a better choice. The Dayton Drives only come in the 11R, they aren't available in 12R. I could put on Firestone FD663 drives in either size.
I don't mind putting on new radials as drives--when I do long trips they are often in harsh environments (Nevada desert in the summer, for example) so heat dissipation and endurance is key.
Thoughts appreciated!
Lucinda
1981 Bluebird All American
Branden is offline   Reply With Quote
Old 07-12-2014, 06:58 AM   #2
bapos's Avatar
Engine: DT466E/MD3060
Re: Tire size and brand question: Move from 12R to 11R?
I use to work for a large tire company for a few years and managed tires for very large shipping fleets.
If it were me I would stick with the 12r. the 11r will be more common to find used for take offs and spares. You are correct it will be a smaller tire. Typically you will only see 12r on a rock hauler type trucks and trailers that need really tall clearance.
Most of the tires you list there other than the firestone are second tier tires. So their quality and longevity is not as good as Godyear, Michelin, etc….Dont want to say you get what you pay for but over the years with tires I think you do.
I would personally go with new steers and recaps on the rear for cost savings. Its what I plan to do if I can not get hooked up from my old employees.
Hope this helps
Old 07-12-2014, 09:27 AM   #3
lornaschinske's Avatar
Year: 1986
Rated Cap: 89
You might check to see if 12Rs are original to your bus. It's not a common size. Could be someone once got a great "deal" on some tires and they just kept replacing with the same size.
I would not think that switching from 12R's to 11R's would be a big deal. You are talking about the width of the tire. Think of it like this... you are traveling down the road, you have a blow out and what are you going to do... get a common spare or sit around waiting on a tire to come in. I vote to switch over to a more commonly available tire. But we also built our bus conversion out of home improvement store to aviod having to go to specialty RV stores and/or wait for replacement parts to come in. We like the freedom allowed in using commonly available parts. Special is nice if you've got the time and money to waste.
It's your bus and your decision to make. No one else can tell you what to do. We can only make suggestions. That is my suggestion.
Fulltime since 2006
Old 07-12-2014, 09:38 AM   #4
Chassis: B3800 Short bus
Rated Cap: 36
And height. 12r22.5 will have 12" tall side wall and 12" wide tread. If the ratio of side wall to tread width is different you'll see numbers like 265/75r22.5. That's probably not a real tire, by the way I just made it up.
I drove a bus with 11r22.5s in the front and 10r22.5s in the back. Surprisingly, it was easy to tell that the front was higher off of the ground.
Old 07-12-2014, 01:03 PM   #5
Year: 1986
Rated Cap: 89
Good for those not so level sites?
Fulltime since 2006
Old 07-24-2014, 09:58 AM   #6
Moderator
crazycal's Avatar
Chassis: 3800
Engine: DT408, AT545
Rated Cap: 23 500 gvw
What does your ID plate say? It. Will list your tire size.
I'm hungry!
You Gotta Let Me Fly
Old 12-23-2014, 09:32 AM   #7
Year: 1972
Coachwork: Homemade
Chassis: Crown Supercoach
Engine: Cummins NHH 220, E-F10spd
My id plate says 11.00-20 for the tires but the PO has put 12r22.5 on my crown. Every shop in town has new 12r22.5 tires but no one has used in this size here in Portland.
Good, Fast, Cheap - Pick any two
Vanopolis is offline   Reply With Quote
Old 12-23-2014, 05:29 PM   #8
Have you thought about "rolling" your fenders? This is where they roll the inner lip of your fender up on itself for a little extra clearance. If this isn't enough you could trim them back. Might not be the entire solution, you might need some more suspension in the back, not sure how yours is configured. But it will definitely help no matter what you do.
While on the subject, can someone explain how bus tires are rated? This is all greek to me.
https://www.skoolie.net/forums/showthread.php?t=9883 - 7.3L 4x4 Shuttle Bus Toyhauler conversion
headinthetrees is offline   Reply With Quote
Old 01-10-2015, 06:01 PM   #9
11x20 is the same size as a 12x22.5 or 11x24.5.
11x22.5 is going to be a little small for a Crown. Itis the same as a 10x20.
I would not use a recap in any position on a bus. When a cap let's loose it will cause some real damage.
For most convertors using cheap Chinese knock offs will do the job at a big savings.
The tires will die of old age long before they wear out
cowlitzcoach is offline   Reply With Quote
Old 01-10-2015, 09:22 PM   #10
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
The id plate on my Crown listed 11x22.5 for tire size
Stu & Filo. T is offline   Reply With Quote
Old 01-11-2015, 06:09 AM   #11
This.
For the amount of miles a skoolie is gonna see- I'd go with the "cheapest" new tires. Just like any RV tire- they WILL die of old age usually not mileage.
Old 08-03-2016, 12:16 PM   #12
Year: 1981
Tire update, a couple thousand miles in.
Just wanted to give an update on the tire situation now that I have some miles under my belt. I'll need to do another because I don't recall what I put on for the steers. I think I wanted to keep the bigger tires up there for the weight rating, and I went with the Dayton 11r from GCR Tire in Seattle. They were great, I would recommend them.
A couple of things also happened in the tire switch: the first, and one reason the bus was riding low, was that there was a broken leaf spring in one of the rear packs. Somehow my previous mechanic never noticed this? Now fixed, and riding higher. Also, I needed new bushings--something that buffers the frame and suspension I think?--all around as the old were smashed and worn out. That added about an inch or less, too.
The tires have been great. I think the idea of a retread really only makes sense in a fleet vehicle where the tread is worn much faster than the sidewall. As has been mentioned before, you will most likely age out of the tire (7yrs, maybe a bit more if you are adventurous) before wearing the tread out. I went with Dayton as a second-tier tire of American make; it was described to me as coming out of the same factory as the top tier but with a lot less choice in sizes and makes. Fine by me.
Regarding size and performance, I knew that the smaller tire would push the engine RPMs up for maintaining any given speed compared to the older, larger tires. Indeed this has been the case. I'm probably up 100-200 RPM. And the top end (right, with a skoolie) has gone from maybe 65 with a tailwind to 63ish. I hardly ever see those numbers anyhow. Mostly I run around 55-60, and the tires have been surprising here. Why is that? you may ask. Well, let me tell you. The bus is "torquier" at higher speeds. Where it used to be difficult to accelerate nearing top speeds, say 50-65, now it runs more like a Maserati (well...). I can go from 50 to 65 in most situations (now, I may not like running it there for comfort, but it can be done) whereas I used to max out wherever the road would allow (smoother=higher speed) as the gearing just didn't have much torque at high speed.
The most noticeable thing about this added power is going uphill. I go to Burning Man, which means I am likely near my GVWR because I'm carrying **** for a circus apocalypse. It also means long grades on I5 from Seattle to Medford, and a half-dozen *nasty* state highway passes. I can now take those at 5mph higher than before. Where I used to be at 15, I'm now at 20. The worst of the worst still has me at 10 mph, but you just gotta be kind to the old Cummins Triple Nickel and it'll get you where you are going. A new radiator helped with the temperature issue, too (that was several years ago, a great investment).
One thing I did was to choose the metro steer tire, for metro buses. My new mechanic, who is also a skoolie guy, suggested a highway steer instead, as the former has a rounded edge from tread to sidewall and the latter a more squared. The metro thus turns a little better, and the highway tracks a little better. He thought there would be less constant steering necessary with the highway version. Meh. I need the exercise.
Lucinda
Old 09-24-2019, 03:26 AM   #13
Gnoman's Avatar
Coachwork: Blue bird
Chassis: All American RE
Engine: 8.3L Cummins 6CTA
Going to revive this old thread as I couldn't find another better fit for my issue. I need a new steer tire due to dry rot (5 good tires are G149 Goodyears, 1 dry-rotted is a Michelin) . I have 12R22.5s on all 6, which is what is stamped on my data plate. This size tire seems impossible to find at a decent price. Has anyone switched the front steer axle from 12R22.5 to the 11R22.5s while keeping the taller 12R22.5s on the rear drive axle? Or even swapped out only the front steer wheels to fit the 11R24.5s to maintain clearance between the two axles?
I'm wondering how much of a difference (ride and mpg) I should expect having ~2 inch shorter tires on the front axle compared to the rear.
If I switched the front wheels to fit 11R24.5 tires, the inner diameter (24.5"?) of the tires would compensate for the 1" loss in sidewall height (x2 for top and bottom sidewall). These also have better load ranges and revolutions would better match the rear reducing speedometer error.
What issues would you see arise if I kept 12R22.5 in rear and moved to smaller 11R22.5 in front, aside from loss in load capacity? Would it be worth it to switch wheels for the 11R24.5s in front?
Opinions?
Gnoman is offline   Reply With Quote
Old 09-24-2019, 11:30 AM   #14
I have routinely swapped out 20" tube type and 22.5" tubeless rims with 24.5" tubeless rims and run 11R24.5 tires without any issues.
The 11R24.5 tires have as great or greater weight carrying ability as 12R22.5 or 315's with the added benefit of being available just about anywhere at much lower cost. I was able to mount a new tire on a used wheel for less $$$ than a 12R or 315R tire cost alone.
Of course I wasn't purchasing Goodyear or Michelin tires. I have found on buses that don't go a lot of miles that purchasing the cheap Chinese knockoff tires are more than adequate for the task. 100% of the time the Chinese tires die of old age before they wear out and will die of old age in about the same amount of time as a name brand tire.
Old 09-24-2019, 01:15 PM   #15
That's my thinking too. The chinese tires are more than adequate for what 95% of us do with a bus.
Engine size question? soused moose Everything Else | General Skoolie Discussions 4 01-16-2015 03:47 PM
Pre-Broken? plumbing + tire question turf Conversion General Discussions 6 01-26-2014 12:32 PM
MY BRAND NEW MINI Shrtbusdrvr Skoolie Conversion Projects 5 01-23-2007 10:12 AM
Basic Question: Oil Pressure, Trans. Size, Governor. greyguzziart Everything Else | General Skoolie Discussions 9 12-24-2006 10:58 AM
Rear End Ratio - Speed - RPM - Tire Size Calculator wmah Everything Else | General Skoolie Discussions 0 10-09-2005 04:27 PM
