Old 07-29-2014, 09:07 PM   #1
Coachwork: Blue bird
Chassis: Handy bus
Engine: 5.9 cummins
Interesting find while removing rear cap of Bluebird
I have a 2002 handybus. It has a wheelchair lift. I am doing some conversion work on it and removed a small rectangle body panel directly beneath the rear door and found an aluminum ramp installed under the bus like you see on the back of a uhaul truck! I guess it was in case the bus was purchased without a wheelchair lift. As I am turning this bus into a giant pickup truck, this ramp will be super handy!
SmokinJ is offline   Reply With Quote
Old 07-30-2014, 09:15 AM   #2
Das Mel's Avatar
Re: Interesting find while removing rear cap of Bluebird
Cooooooooool.
'Tace
Dog is my copilot. As I have no dog, I have no flight plan.
"If all porkchops were perfect, we wouldn't have hotdogs!" -Steven Universe
Das Mel is offline   Reply With Quote
Old 07-30-2014, 01:47 PM   #3
Location: Alachua County, Florida until we get out of there
Does your bus have wheel wells coming up out of the floor? Someone else here had a wheelchair bus with flat interior floors and a ramp also, so it would be interesting to see if the option comes with a raised interior floor and a conventional floor also.
Hmmmm.
And what length is your bus, if I might be so bold to ask?
abwetzel63 is offline   Reply With Quote
Old 07-30-2014, 05:46 PM   #4
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
Boy you have a lot of nerve !!!!
Stu & Filo. T is offline   Reply With Quote
Old 07-30-2014, 07:45 PM   #5
Yup. Lots of nerve. That's why I have an Anxiety disorder!
Uhoh, I think we just hi-jacked the thread...
Old 07-30-2014, 09:06 PM   #6
Chassis: Handy bus
Engine: 5.9 cummins
The bus is 32' long. I don't believe the wheel wells come up through the floor like most.
Options / Ideas for removing rear heater. Josef Conversion General Discussions 3 02-26-2018 03:24 PM
How to remove rear windows - Bluebird White99z Conversion General Discussions 7 07-26-2016 02:41 PM
Removing rear heater and 1 inch hosing timbrass Heating, Cooling and Appliances 2 11-24-2014 06:36 AM
1999 BlueBird International - Rear Brakes NilesSkoolie International | Navistar Drivetrain 8 03-04-2013 12:38 PM
Removing rear heaters / cap lines? buswizard Conversion General Discussions 4 07-17-2010 07:46 AM
