Old 07-29-2014, 09:59 PM   #1
Chassis: 3800
Engine: Diesel, international
Floor prep?
Finally got the seats, rubber floor and plywood up. Floor looks good minimal rust with the normal numerous screw holes. I plan on caulking the holes and covering with aluminum tape. Insulation board, moisture barrier and 1/2 inch plywood covered with vinyl plank flooring. My question is what do I paint the floor with prior to insulating and do I need an additional rust preventative prior to painting? If anyone sees something wrong with my plans please share.
Bureau602 is offline   Reply With Quote
Old 07-30-2014, 09:32 PM   #2
Chassis: Genesis
Re: Floor prep?
Scrub the floor clean with TSP.
Spray out the bus with water.
Let dry.
Spray down a layer of Ospho to etch the zinc.
Let dry.
Paint with Rustoleum Pro primer.
Let dry. Open the windows to get ventilation or it will take forever.
Paint with Rustoleum Pro top coat or two.
Timelord is offline   Reply With Quote
Old 07-30-2014, 09:41 PM   #3
Chassis: 3800
Re: Floor prep?
Thanks. What exactly is TSP?
Old 07-30-2014, 09:51 PM   #4
lornaschinske's Avatar
Year: 1986
Rated Cap: 89
Re: Floor prep?
Tri-Sodium Phosphate Heavy Duty Cleaner that cleans pretty much anything also a TSP substitute as TSP is not enviromentally friendly and cannot get into the waterways.
Generally found in the paint dept.
Fulltime since 2006
Old 07-30-2014, 09:54 PM   #5
Year: 1986
Rated Cap: 89
Re: Floor prep?
"Ospho" refers to a brand name of phosphoric acid.... alos tends to be in the paint dept.
Fulltime since 2006
Old 07-30-2014, 10:10 PM   #6
Chassis: Genesis
Re: Floor prep?
Ospho is more than just phosphoric acid. The website says "SKYCO OSPHO: a balanced formula of Phosphoric, Dichromate, Wetting Agents and Extenders..." It is good stuff.
(Spray) Paint Job. Pre/Post prep. bassbus Conversion Tutorials and How-to's 14 07-21-2019 03:11 PM
Harsh winter prep for full-time RVing? tomas_maly Conversion General Discussions 5 06-17-2016 06:51 PM
jasco Prep and Primer MissJaneStrummor Short-Bus Conversion Projects 12 02-21-2014 07:33 AM
Paint prep opus Conversion General Discussions 14 07-22-2010 04:10 PM
3/4 ply vs 3/4 osb for floor busone Skoolie Conversion Projects 6 10-09-2005 09:07 PM
