Old 08-22-2014, 07:26 AM   #1
Chassis: Bluebird
Engine: International something
Engine Swap or Gear Change to Go 70mph
I have a s1700 blue bird on International frame. It has the 7.2liter diesel engine and it is governed at 55mph with the wind behind you and going down hill. I hate that it goes so slow because that means we do not get to go to many away games with the bus. What would be the best bang for my buck? I do not know the gear ratio. I also heard that if the governor is removed the engine could burn itself up. The engine right now in the heat of the summer runs at around 210-230F. Going up hills is embarrassing on the interstate. PLEASE HELP!
http://www.facebook.com/autp2
garbemi is offline   Reply With Quote
Old 08-22-2014, 12:49 PM   #2
Coachwork: Honey Badger RV Co
Chassis: tc2000
Engine: 5.9 cummins
Rated Cap: 74
Re: Engine Swap or Gear Change to Go 70mph
Should be a tag above the winshield with gear ratio stamped on it.
wauto is offline   Reply With Quote
Old 08-22-2014, 12:54 PM   #3
opus's Avatar
Chassis: All-American R/E
I dont think a 7.3 will respond well to a gear change. Doing anything with the gov will only result in negative long term issues.
Rear axle gear ratio. To change or not to change. slade Conversion General Discussions 15 04-24-2017 02:33 PM
rear end gear ratio change Atridox GM | Chevrolet Drivetrain 2 08-13-2012 09:24 AM
how much time to swap engine? kyletheyeti International | Navistar Drivetrain 8 01-17-2012 12:24 PM
Engine swap... abdabbs Conversion General Discussions 1 10-31-2008 01:59 AM
Engine,Gear ratios, GVW, mph???input JoeA Conversion General Discussions 8 01-15-2007 11:42 AM
