Old 08-26-2014, 10:50 PM   #1
Coachwork: Still Looking
Chassis: Eventually a short bus
Engine: Diesel
Hydronic heater and hot water
So I did read where some of the short busses have the rear heater run off of the engine radiator. Has anyone thought of using an on demand lp water heater for both domestic and for the heater. Two separate loops, back flow preventers, valves, expansion tank and a pressure relief valve. If I bought the hot water heater and a forced air heater we're up to over $800.00+. I have the existing hot water core (heater) and pump. Keeping both systems separate and using a flat plate exchanger that both loops go through. Only the heating loop would go through the on demand heater. If you wanted hot water at the sink, turn a couple of valves so the heating loop would be much smaller and not going through the heater core. If you needed heat, turn the valves to open so hot water would flow to the heater core. I would also possible up the temperature as well if you wanted heat. I can picture this in my head, but my only concern is having non moving water in half of the exchanger because no hot water is needed for the tap. The easy solution is to isolate the heat exchanger so the heating loop doesn't go through it when only heat is needed. I'm looking at the Bosch 330 PN. Piezo ignition and pilot light until you turn the gas off. Any thoughts? It's complicated, but I thing it would work great. On demand heaters are used with solar water heaters to bring the water temperature up if needed. It would not turn on unless the water going through it dropped enough for the thermostat to start the unit.
DaveLind is offline   Reply With Quote
Old 08-27-2014, 08:39 AM   #2
lornaschinske's Avatar
Year: 1986
Rated Cap: 89
Re: Hydronic heater and hot water
You need to learn how a hydronic system works. Best source for a vehcile based system is over at Aqua-Hot. Read their website to see the various options. Then look in their Library for a similar sized product to what you would have and download the installation, service and parts manuals. The part manual will tell you everything you would need to build one plus how it all goes together (or at least the old one I have does). Once you have that and understand how the set up works, then you can build a hydronic sytem for yourself. You must use fluid pumps that are made for hot fluids. Not regular water pumps. We bought ours off of Amazon. You must keep your potable water and your heating fluid seperate. Anti freeze is deadly and the "pet friendly" stuff isn't healthy. Oasis also has their manuals online too. Toe kick heat exhangers can also be bought. Cabin Craft is the brand you see for boats. At one time, I had planned to use a couple of Cabin craft heat exchanger kits for boats located thru either West Marine or Defender Marine. That was for the Eagle 05. I had figured out how to build a system similar to an Aqua-Hot for 1/3 of the price. For the skoolie, that same exact system would have been more than the shell cost. We refuse to put a $2K (more now with inflation) heat system in a $1400 shell. Not when we can do it for less and have more redundency. Our hydronic heat system won't be finished and operational until we get someplace that we can openly work on the bus. Until then we will stick with what we have. Don't forget that you don't want to heat your bus in the summer time. Based on what I learned, we decided that, for us, seperating the systems was cheaper and easier to run & repair.
At it's simplest, this is a simple, bare bones, frugal, hydronic heating system for an RV...
The "car heater core" and fan in the image would be the fan forced rear heat exchanger from your bus. All you would need is a heat source and a hot fluid pump.
Put together wrong, a hydronic heat/potable water system can be deadly. Read up and truly understand what you are doing before you do it. If I remember correctly, to use a tankless water heater in a potable water side hydronic loop (not to heat the loop but to boost the water temp) you need to get a tankless water heater with what was called the "solar option". These tankless water heaters were designed to use already warmed water from solar batch heaters and boost the already warm water to bathing temps. They are different and more expensive. Seems already warm water messes with the sensors of standard tankless water heaters. From what I have read, the Eccotemp L5 that we own would have that problem. Otherwise it would be shoved inline between the water heater and the washing machine. As it is, the L5 we have is so tempermental that we have held off testing it to see how it will work with the washer. We will hold on to it and wait. Besides, the water here in NM is so high in minerals that I really don't want to run much thru the machine until I get a water softener on the bus.
Fulltime since 2006
webasto diesel hydronic heater worth it? jeremywilliams Classifieds | Buy, Sell, Swap 6 11-06-2014 03:53 PM
Rear hydronic heater & under bus piping DaveLind Heating, Cooling and Appliances 5 10-12-2014 10:48 AM
Bus Hydronic Heater Issue Henukaw Conversion General Discussions 5 11-10-2012 02:32 PM
How's THIS for a hydronic heater??? oldog12 Conversion General Discussions 0 10-18-2009 02:14 AM
Bus engine as a water heater Steve Conversion General Discussions 20 07-07-2006 01:53 PM
