Old 07-25-2013, 05:57 AM   #1
Chassis: Saf-t-liner
Engine: Cat 3126 - MD 3060
Credit Score 1000 Bus
Figured I'd start my build thread. It's going to take forever, it's me, wife and 3 kids age 4-7-10. I'm hoping someday our bus is nice enough to full time, we are minimalists who starve for adventure so I think it will work. Plus I'm not too psyched on the mortgage payment. We aren't planning anything spectacular accept a possible loft bed for the master bed.
ThePimentals is offline   Reply With Quote
Old 07-25-2013, 06:08 AM   #2
Re: Credit Score 1000 Bus
Went for the seats first thing because I want to visualize our floor plan
Old 07-25-2013, 06:13 AM   #3
Old 07-25-2013, 06:45 AM   #4
ooooo, oo,,,
a submarine!! cool
Old 07-25-2013, 09:19 AM   #5
paxye's Avatar
Chassis: All Canadian
We are just getting started with our conversion also... and I get you... it will take forever with us also! For us it is me, the hubby and 4 kids (11, almost 9, almost 7 and 3.5) We are also pretty minimalistic, though there will be a lot to get rid of still and we are looking forward to being on the road full time.
We are planning a loft bed in back also... but I am still back and forth of how we are going to make the kids fit...
I look forward to seeing the progress...
Melissa *A hippie with a minivan*
paxye is offline   Reply With Quote
Old 07-25-2013, 10:09 AM   #6
JakeC's Avatar
Originally Posted by ThePimentals
File comment: The brackets were tedious really, luckily I'm a welder so I don't mind being sprayed with sparks because I wasn't wearing long sleeves in this heat, 92 with 79 humidity. The brackets took 2 days work, cut the heads about 2/3 off and grinder the rest, it's nice to be able to walk around the empty bus, it feels serene almost, because I know what the plan is for it.
Haha... I can relate!! The red specks covering your arm (in the event of a real good spark shower) disappear quickly
Brutus
Old 07-25-2013, 10:16 AM   #7
wmkbailey's Avatar
Engine: 3126
Thanks for showing how you got the seat feet up. I will be tackling that next.
It will be just my dog and I. Since everone else is getting a loft bed, now he wants one too.
When done this bus will be our full time home. I hope to move in by next spring and finish up as I go. I'm going a little more extreeme, roof raise and spray in insulation, no LP and composting toilet. All I will have is fresh water tank inside and grey water under. With no LP, no vents to cut in the bus.
Look forward to seeing you progress
William
https://thejourneyvisvi.com/
My Conversion Thread:
viewtopic.php?f=9&t=464989
Old 07-25-2013, 10:20 AM   #8
lornaschinske's Avatar
Year: 1986
Rated Cap: 89
You will need to vent the grey tank at the roof line. You are no different from the rest of us in that your grey water will smell.
You might want to checkout how some of the bunkhouse toyhaulers set their beds up. You may get some ideas. If you can locate websites for the folks who build bunkhouses for the circus and carnival folks, that would be helpful. They custom build some amazing units. I used to have some links but lost them.
Fulltime since 2006
Old 07-25-2013, 11:14 AM   #9
wmkbailey's Avatar
Engine: 3126
Ok, I will have less vents
William
Old 07-25-2013, 01:44 PM   #10
Diesel Dan's Avatar
Engine: DT466/AT545
I really don't want to cut a hole in my bus roof for a grey tank vent. I'm thinking of running my vent up the outside wall of the bus, maybe in the back. It might look a little funky, but if I keep adding other funky things then it all works.
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 07-28-2013, 04:49 PM   #11
Old 07-28-2013, 05:21 PM   #12
wmkbailey's Avatar
Engine: 3126
The weather was nice here too. I should have taken off and went camping in the bus. I will have to remember next time we have cool weather. I ran my Webasto heater and it worked good, I had heat in five minutes.
William
Old 07-29-2013, 06:11 AM   #13
The heating lines that run the length of the floor are pretty annoying right now actually, I took all the panels off so I could get to the rest of the floor, I like the idea of running the lines under the bus, but its more work, I don't want to just cover them inside the bus either though. Basically I'm annoyed. The heater is nice though.
Old 07-29-2013, 11:03 AM   #14
opus's Avatar
Chassis: All-American R/E
If you run the lines under the bus it will be way too much work, plus you will lose heat. Mine just sit on the floor, uncovered. Extra heat and you will see right off if you ever get a leak.
Old 07-29-2013, 11:11 AM   #15
JakeC's Avatar
I see you kept the chair rail. I used the area under the chair rail as a channel to run the heater lines, pex lines, and wiring. Works really nice and the majority of it ended up easily accessible.
Brutus
Old 07-29-2013, 11:50 AM   #16
Originally Posted by bansil
ooooo, oo,,,
a submarine!! cool
100MPG is offline   Reply With Quote
Old 07-29-2013, 01:53 PM   #17
wmkbailey's Avatar
Engine: 3126
Hey bus brother,
I forgot to ask, is the rubber gluied to the steal or is there plywood between the rubber and steal?
William
Old 07-29-2013, 02:10 PM   #18
Glued right to the steel. No wood.
Old 07-29-2013, 02:15 PM   #19
wmkbailey's Avatar
Engine: 3126
Wonderfull
William
Old 07-29-2013, 08:15 PM   #20
Coachwork: Ward Genesis
Engine: DT466/MT643
Hey, another New Englander! Welcome.
Jarlaxle
Optimism is a mental disorder.
Jarlaxle is offline   Reply With Quote
Great WVO score sdwarf36 Alternative Fuels | Electric, Propane, Wood & Biofuels 4 02-23-2016 11:56 AM
How far will $1000 get you in a conversion? mannypacquimeow Conversion General Discussions 13 08-11-2014 01:58 PM
Another score for Gore Redbear Everything Else | General Skoolie Discussions 0 10-31-2010 07:29 AM
Auction SCORE!! oakspring Conversion General Discussions 0 05-15-2010 10:44 PM
eBay skoolie for $1000. EldoMike Classifieds | Buy, Sell, Swap 9 04-20-2005 05:59 PM
