Old 05-04-2014, 10:04 PM   #1
kenny76's Avatar
Engine: Cummins 5.9
RV There Yet? The tale of a 92 BB TC2000
We started our work on the bus this week end. We were able to get the remaining 8 rows of seats out, the floor up, cleaned and prepped and alas painted. I will post some pictures as soon as I figure that task out.
Not all those who wander are lost.
kenny76 is offline   Reply With Quote
Old 05-05-2014, 04:38 AM   #2
Chassis: international
Engine: 7.3 Navistar
Re: RV There Yet? The tale of a 92 BB TC2000
cant wait to see the work..........get them pics up
95bluebird is offline   Reply With Quote
Old 05-05-2014, 01:08 PM   #3
mrtravelingman2's Avatar
Year: 1960
Engine: 283 cid
Hi kenny76 Yes we all want to see pictures, but posting them is not always easy. I found a place that will hoist your pictures free. You just have to copy the link for forms/message boards. But as with all free sites it is best to always keep a copy of your pictures on a flash drive just in case. Also I resize my pictures with paint to 700x525 pixles as they will upload faster.
Here is the site http://tinypic.com/
The best of luck with your build and will await your pictures the old man Richard
mrtravelingman2 is offline   Reply With Quote
Old 05-05-2014, 06:26 PM   #4
Chassis: bluebird
Rated Cap: 16
Love the name, RV there yet? I named mine Betsy for the simple reason of not having anything better in mind. Though that seems to be a theme. My wife renamed one of our cats when he started answering to "furry little bastard"........
orangepeel91 is offline   Reply With Quote
Old 05-05-2014, 10:46 PM   #5
kenny76's Avatar
Engine: Cummins 5.9
http://<a href="http://s1057.photobu...&#91;/img]</a>
Old 05-05-2014, 10:47 PM   #6
kenny76's Avatar
Engine: Cummins 5.9
Old 05-05-2014, 10:49 PM   #7
kenny76's Avatar
Engine: Cummins 5.9
Old 05-05-2014, 10:51 PM   #8
kenny76's Avatar
Engine: Cummins 5.9
Old 05-05-2014, 10:52 PM   #9
kenny76's Avatar
Engine: Cummins 5.9
Old 05-05-2014, 10:53 PM   #10
kenny76's Avatar
Engine: Cummins 5.9
Old 05-05-2014, 10:54 PM   #11
kenny76's Avatar
Engine: Cummins 5.9
Old 05-05-2014, 10:55 PM   #12
kenny76's Avatar
Engine: Cummins 5.9
Old 05-05-2014, 11:00 PM   #13
kenny76's Avatar
Engine: Cummins 5.9
Just a little note, according to Rustoleum, you cannot use many of their products on galvanized metal because of a chemical reaction called soaponification (sp) that will occur when you use an alkaloid based paint on a galvanized metal. They recommended the use of Zinser 123 which is what I used. I saw the warning just before I popped the lid on my Rustoleum Rusty Metal Primer. I made a call to the customer service number on the can and they directed me to the Zinser.
Old 05-06-2014, 09:38 AM   #14
Roger that --- Painting galvanized requires special treatment. There are also etching primers made specially for use on galvanized as well. Ordinary paint won't adhere without it and as you discovered there can also be chemical reactions between the zinc and certain paints.
Old 05-06-2014, 08:11 PM   #15
kenny76's Avatar
Engine: Cummins 5.9
Ok so how can I determine which Allison I have? This is important to me because I am considering modifying the governor spring to get the ability to maintain a safe speed while driving in less than flat terrain.
Old 05-06-2014, 10:47 PM   #16
Chassis: IH
Engine: 466
Rated Cap: 64
viewtopic.php?f=44&t=1824
This should give you what you need to figure out which trans you have!
dburt is offline   Reply With Quote
Old 05-07-2014, 09:10 PM   #17
kenny76's Avatar
Engine: Cummins 5.9
I looked at that last night and I cant say 100% that it is either. I am almost certain it is the dreaded 545. I will look from the passenger side in the daylight if I get the chance. I started a new job week before last, have gotten a lot of new fire cases, finished up a term on my masters degree and got stuck in jury duty all week so I have been busy. My wife was able to get the title done and tag home. The insurance was a bit delayed because of the underwriting process but its insured for a year for $340.00.
Old 05-10-2014, 07:39 PM   #18
kenny76's Avatar
Engine: Cummins 5.9
I don't know who else has been working on the demo side of things, but I worked all day on our bus today and seem to have gotten very little accomplished. I took a break on rivet busting for a bit and installed the rear door lock. I feel better about leaving some of my tools in her over the week now. As far as the rivets go I have no idea what they made the ones on my bus out of but it actually curled the edge of my air chisel. I went to the depot and bout a small sledge and a 3/4" cold chisel with a safety handle. Takes alot of whacks but eventually the head shears off. 88 rivets down several hundred more to go. The next to the last panel at the rear of the roof is on the ground. I am hoping this extra work is gonna be worth it.
Old 05-11-2014, 08:20 AM   #19
kenny76's Avatar
Engine: Cummins 5.9
Nat,
Your posting about the hand chisel is why I went ahead and bought one at the depot. It's a whole lot of hammer swinging when its 4-5 strikes per rivet multiplied by the remaining 200+ rivets. I was hoping for a faster way. The drill method is so slow its almost faster to watch them rust out. I even tried an oscillating tool to saw the head off. Ended up with a toothless blade and 10 minutes less time.
Old 05-11-2014, 02:53 PM   #20
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
I tried drilling & grinding & chisel, were I could I cross ground the heads then one maybe 2 hits with a chisel, were I couldn't, 4 to 6 hits with a chisel, cross grinding prevented distortion
Stu & Filo. T is offline   Reply With Quote
96 BB TC2000 - Spokane, WA opus Classifieds | Buy, Sell, Swap 1 10-24-2014 12:10 PM
Tale of 2 Buses Apacheglen Skoolie Conversion Projects 20 09-17-2013 11:43 PM
93 BlueBird TC2000 FE 72/40 ft Abbott Everything Else | General Skoolie Discussions 15 06-16-2009 10:20 PM
My TC2000 The Wanderer Skoolie Conversion Projects 29 04-21-2007 08:01 AM
1991 TC2000 FE newfoundlandshark Conversion Tutorials and How-to's 1 03-10-2006 02:14 PM
