Old 08-15-2014, 11:15 AM   #1
miniman's Avatar
Chassis: TC1000
Engine: 5.9L Cummins
Rated Cap: 26
99 TC1000 "The Struggle Bus"
Here she is, I am starting this build thread a bit late so my apologizes if some photos are out of order. Also lots of bad snapchat screenshots from friends.
1999 TC1000
5.9L 24valve cummins
180,000~ miles
Ricon Wheelchair lift
Internal AC / heaters
L-track rail system for wheelchairs / seatbelts. This will become very important in our build.
miniman is offline   Reply With Quote
Old 08-15-2014, 01:16 PM   #2
Chassis: TC/1000
Engine: Cummins ISB 5.9L
Rated Cap: 34
Re: 99 TC1000 "The Struggle Bus"
Long live the struggle bus!
jlroettger is offline   Reply With Quote
Old 08-15-2014, 01:17 PM   #3
Welcome, interesting fender wheels, does it have a flat floor?
Apache junction....that brings back memories from 1978
Keep up the pictures
Old 08-15-2014, 01:21 PM   #4
miniman's Avatar
Chassis: TC1000
Rated Cap: 26
Here are some photos of the drive back from Apache Junction Arizona to SoCal.
In the city:
So majestic:
Blends right in?
Knocking the dust off!
Old 08-15-2014, 01:23 PM   #5
miniman's Avatar
Chassis: TC1000
Rated Cap: 26
Yes it has a flat floor, I will keep posting pictures and show you!
Old 08-15-2014, 04:18 PM   #6
miniman's Avatar
Chassis: TC1000
Rated Cap: 26
Top speed, downhill!
Here it is with the seats pulled out (really easy because of the rail system!)
Only had 6 seats in it I think, the rest was for wheelchairs
Old 08-16-2014, 04:42 PM   #7
Looking good!
Laurel is offline   Reply With Quote
Old 08-16-2014, 07:40 PM   #8
Engine: Cummins VT555
Awesome! We really want to find a short flat nose like this to turn into a little camper after we turn our full size bus into a home
LuckyHenriksen is offline   Reply With Quote
Old 08-17-2014, 10:38 AM   #9
From what I've seen, it appears the "flat floor" Birds have the potential for massive underbelly storage. Solid looking unit, keep the pix coming.
Old 08-18-2014, 10:29 AM   #10
miniman's Avatar
Chassis: TC1000
Rated Cap: 26
Unfortunately most of our underbus space is taken up by AC condensers. We are going to try and sneak a truckbox or 2 under the wheelchair lift area as it has plenty of free space, probably about 48"
Old 08-18-2014, 12:11 PM   #11
miniman's Avatar
Chassis: TC1000
Rated Cap: 26
Testing out our sleeping accommodations
Turns out that the current speakers use a shared ground (no good for quality) so that will be getting rewired
Taking off the rails to get to the cables
left Rails off
My friends reaction after breaking the cable we were using to pull new wire through the bus walls. This sucked.
Old 08-18-2014, 12:47 PM   #12
miniman's Avatar
Chassis: TC1000
Rated Cap: 26
Here we are starting to pull out the floor, This also sucked. I think the guys in the bluebird factory have ADD - some areas have glue pooled and others are very sparsely glued.
Here we are drilling a big hole in the door to install a lock (we used a garage door lock as someone else on here recommended)
Playing the rubber floor guitar.
Old 08-18-2014, 06:02 PM   #13
miniman's Avatar
Chassis: TC1000
Rated Cap: 26
The team working hard.
To understand the bird, one must become one with the bird.
Removing the L-Track rails is dirty work.
All of the floor and L-Track is out. Time to start cutting wood pieces to fit into the rail spots that we are not going to be keeping.
Old 08-18-2014, 06:14 PM   #14
miniman's Avatar
Chassis: TC1000
Rated Cap: 26
Tablesaw = FREE, ZILCH, ZERO, NADAAAAAA. although it has seen better days, i think it will get the job done.
Test mounting the TV. (this was a joke)
Safety first?
Some coworkers bought us some motivation swag.
Old 08-18-2014, 06:20 PM   #15
miniman's Avatar
Chassis: TC1000
Rated Cap: 26
Track spacers are cut and in, ready for staples and glue
Sanding the wood down to size
Wood puddy where needed
Rolling out underlayment for the Laminate flooring
Some fine looking fake wood we have here!
Old 08-18-2014, 10:23 PM   #16
sdwarf36's Avatar
Coachwork: Champion
Chassis: Ford e-450
Engine: 7.3 Powerstroke
Oh man-I NEED one of those key fobs! How-where-how much?
Old 08-19-2014, 09:13 AM   #17
I love the shirts, got a link for them?
And great job and I like how you folks are having fun!
just keep it safe....damn I'm getting old
Old 08-19-2014, 04:19 PM   #18
miniman's Avatar
Chassis: TC1000
Rated Cap: 26
I think the keychains came from here: http://www.zazzle.com/short+bus+gifts
but they were a gift so we are not sure.
Old 08-19-2014, 04:54 PM   #19
miniman's Avatar
Chassis: TC1000
Rated Cap: 26
Flooring is mostly in - We are keeping the outer 2 rails so that we can mount sofas and cabinets.
Here is the floor with the rails installed
Very cheap LEDs for interior lights from china of course.
Pretty bright and much lower power consumption than normal lights.
Old 08-19-2014, 04:59 PM   #20
miniman's Avatar
Chassis: TC1000
Rated Cap: 26
We reused some existing bus trim pieces for our flooring. Might get updated in the future, right now this works great as a low/no budget option.
Here we are starting to create the floorboards - not sure if anyone else on skoolie has used a technique like this.
Each of the floorboards has AC / DC on one side, and on the other side they have AC / DC / HDMI / RCA audio / Ethernet wiring for our keystone wallplates
1986 Intl/Thomas Conventional, DT466 5speed, "Big Blue Bus" thrash Skoolie Conversion Projects 8 08-25-2013 11:57 AM
"Short" bus or "Regular" bus? TygerCub Conversion General Discussions 11 03-03-2012 12:37 PM
up for auction!! 1972 GMC "New Look" "Fishbowl" Coachbus35ft Stuff Classifieds | Buy, Sell, Swap 0 01-18-2011 10:39 AM
"Tutorial" and "How To" internal error dunnwright Conversion General Discussions 6 11-16-2010 07:02 AM
sKOOLie search and seizure - "mobile home" legalit skoolie_grease Everything Else | General Skoolie Discussions 19 01-23-2006 04:04 PM
