Old 11-10-2014, 06:18 AM   #1
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
To the tire Guru's
I got a set of 6 really good Michelin XRV tires for FREE, mine are a bit scary weather checked on the sidewalls. The only problem is they are a bit smaller. I've made up a
spread sheet to see road speed differences. This is the final result. Any comments? Do you think the difference is something I can live with?
Thanks,
Dick
Old 11-10-2014, 09:18 AM   #2
Re: To the tire Guru's
Since you are still well within the load limits, my first question would be..."at what Engine RPM?"
The ideal combination of tire diameter and final gearing allows you to maintain your preferred highway speed on level ground at or very near the engines "sweet spot" which is typically close to it's peak torque RPM. Check your engine's specs and work back from there.
Too few RPM's and the engine will "lug" and have to work too hard...too many and it will suck way too much fuel and have a shortened life span. Balance the numbers out and you will get the best of both. Some conditions warrant changing out the gearing. Mine did.
Best of luck, and let us know what you discover.
Old 11-12-2014, 11:25 PM   #3
I would second the comments about effectively changing your rear gearinig. By going to a shorter tire it is going to lower your top speed by 3-5 MPH.
The other comment I would have is I have had really poor service out of Michelin tires.
Depending on how the tires have been stored you may be swapping tires that are in poorer condition than your current tires.
cowlitzcoach is offline   Reply With Quote
Old 11-13-2014, 12:29 AM   #4
If you need tires for your bus --- Check with local commercial suppliers. Michelins' are "good" tires but there are better, more economical choices available. Bridgestones, for example, have a great reputation among commercial users who run their fleet vehicles 24/7/365. Big rig tire vendors are another good source for straight info.
RV tire blowout wmkbailey Everything Else | General Skoolie Discussions 0 09-04-2013 09:28 AM
Tire Pressure? TygerCub Conversion General Discussions 20 07-19-2012 07:11 PM
Need A Ford Guru....... paul iossi Ford Drivetrain 6 12-08-2009 08:26 PM
Questions for the seasoned BUS GURU'S Papabear Mechanical and Drivetrains 14 11-05-2009 09:32 AM
Air Brake Guru's ?? hoser Everything Else | General Skoolie Discussions 7 03-31-2006 10:29 PM
