captainkf wrote:Looks great! What kind of carpet did you use for the walls and ceiling. I have been thinking of somthing like that for ours as it is a bit boomy inside. Was it expensive? How did you install it? What kind of glue did you use? What happens if you decide to remove it in the future, will it come off without massive work?
This month's pictures are at:
http://picasaweb.google.com/Mark.D.Zimmerman/BusFEB07
I used the lightest (16oz per yd2) outdoor carpet I could find at Lowes and used their indoor/outdoor adhesive trowelled (?) according to directions. Logic for using the outdoor stuff is that any leaks wouldn't have such a negative effect on the finished product. The glue also has antimicrobial properties and is supposed to fight mold and mildew in the event of moisture incursions. I'll get closeups of the carpet and the glue used this weekend when I'm back out there working. This covers up all sorts of sins with the wood work, including those places where my bulkheads meet the curve of the cieling. I did a pretty good job matching the curve, but with the carpet in place, it's spotless.
The walls went up very easy, as the carpet is so very light. The ceiling was a little more tricky and i ended up cutting the carpet in 28" strips to go inbetween the ceiling seams. Once the cabinets are up down each side of the bus, I'll put in some 1" trim strips (probably that fake plastic wood trim stuff since it's flexible) to cover up the gaps. I'll use glue or screws to hold them in place.
As for removal, I already took one piece off one of the walls to get inside the plywood for adding some electrical wiring (Planning is for sissies). It was pretty tenacious, but it came off in one piece and didn't require much in the way of preparation to hang the replacement piece. This particular spot had been set up for about a month.
Anyway, more pics this weekend. My move in day is now 7 weeks away, so it's time to get cracking!
