Old 07-30-2004, 03:04 PM   #1
Steve's Avatar
Identify those wheels.
Rim
The rim supports the tire. There are two types of rims: a single piece rim (tubeless-some 16 inch single piece rims are either tubeless or tube-type) and a multi-piece rim (tube-type). A Single-Piece Rim is a continuous one-piece assembly. A Multi-Piece Rim is an assembly consisting of a base and either a side ring or a side and lock ring depending on the type. A Demountable Rim does not have a center disc and is clamped onto a cast spoke wheel.
Tubeless Demountable Rim (single piece)
shown in cross section
Tube-Type Demountable Rim Assembly (multi-piece)
Disc Wheels
A permanent combination of a rim and a disc attached to the hub by studs and nuts.
Tubeless Disc Wheel
Tube-Type Disc Wheel Assembly
Cast Spoke Wheel
As the name implies, it consists of a casting which includes the hub and either 3, 5 or 6 spokes. This is an axle component that demountable rims are attached to with clamps. There are designs with different numbers of clamps with various shapes. Each cast spoke wheel requires clamps designed for the cast spoke wheel. A spacer band is used with duals on rear cast spoke wheels. Typical designs are shown.
5 Spoke
Cast spoke wheel with brake drum and clamps (for rear axles).
5 Spoke
Cast spoke wheel with clamps, without brake drum (for front axles).
Spacer Band
Used on rear cast spoke wheels the spacer band holds the two rims apart and provides proper dual spacing for the tires.
Split Side Ring
In two-piece assemblies, the side ring retains the tire on one side of the rim. The fixed flange supports the other side. The split side ring is designed so that it acts as a self-contained lock ring as well as a flange
Split Side Ring
Flange or Continuous Side Ring
In three-piece assemblies, the flange or continuous side ring supports the tire on one side of the rim. The continuous side ring is, in turn, held in place by a separate split lock ring.
Lock Ring
All lock rings are split. In three-piece assemblies, the lock ring is designed to hold the continuous side ring on the rim.
Split Lock Ring
Studs and Nuts for Disc Wheels
Typical examples of studs, nuts and clamping plates used with disc wheels are illustrated in this section. A typical stud (Fig. 1) used with in-board brake drums has a 3/4" thread on both ends, a shoulder with two flats, and is longer from the shoulder on the one end with an unthreaded section. The flat surfaces of the shoulder fit into the recessed outer surface of the hub to keep the stud from turning. The smooth portion is long enough to fit through the hub and the brake drum, and is then held in place by a back or jam nut (Fig. 2). For outboard brake drums a serrated stud with threads on one side is typically used (Fig. 3).
On front stud piloted wheels, an outer cap nut (Fig. 4) or (Fig. 6) is used. On stud piloted rear dual wheel applications, the inner wheel is held in place by an inner cap nut (Fig. 5) and the outer wheel by an outer cap nut (Fig. 6).
For hub piloted wheels which pilot from the center hole, flange nuts are used on both the front and rear wheels. One-piece flanged cap nuts (Fig. 7) are used on light truck and medium truck applications. Heavy trucks and buses and some light trucks use a two-piece flange nut or swiveling lug nut (Fig. when hub piloted wheels are used. Some light trucks use a clamping plate (Fig. 9) and 90° cone nuts (Fig. 10) for both the front and rear wheel. Light trucks which use single wheels on the front and rear axle require 90° cone nuts or 60° cone nuts (Fig. 11), depending on the truck manufacturer.
Rim Clamps, Studs, and Nuts for Demountable Rims
The stud for cast spoke wheels (Fig. 12), threaded on both ends, is installed in a threaded hole at the end of a spoke. The front clamp (Fig. 13) and a rear clamp (Fig. 14) hold the demountable rim in position with studs and nuts (Fig. 15). A clamp for a three-spoke wheel with two stud holes is shown in (Fig. 16).
Information taken from the Accuride safety manual.
Old 06-07-2011, 08:32 AM   #2
bapos's Avatar
Engine: DT466E/MD3060
Re: Identify those wheels.
Not sure if others are looking at this but all the images are broken.
Old 06-07-2011, 04:57 PM   #3
Stuff's Avatar
ditto
Old 06-08-2011, 10:59 PM   #4
otto802's Avatar
Year: 1987
Coachwork: Ward
Chassis: Volunteer 6-Window
Engine: Propane
That's what happens to threads that are 7 years old!
otto802 is offline   Reply With Quote
Old 06-09-2011, 10:22 AM   #5
Stuff's Avatar
hahahaha i didnt even notice that!
Identify this bus for me? opus Everything Else | General Skoolie Discussions 6 05-08-2013 03:39 PM
87 Chevy 366 - Identify this box? jaredg GM | Chevrolet Drivetrain 4 10-07-2012 10:04 AM
Can someone identify this component? frank-id Mechanical and Drivetrains 4 09-13-2012 03:54 AM
Help me Identify this bus opus Everything Else | General Skoolie Discussions 4 12-22-2010 01:27 AM
Identify my rear end... jkindt Mechanical and Drivetrains 4 05-02-2010 08:31 AM
