Old 03-29-2005, 02:12 PM   #1
Eric von Kleist's Avatar
Year: 1985
Coachwork: ThomasBuilt
Chassis: International Harvester S-1700
Engine: 9L IHC V-8 Diesel 180HP
Rated Cap: 60
Holding Tanks
Well, I'm trying to come up with free holding tanks, and if not free ones, at least cheap ones.
I stopped in at a plumbing supply place to price 8" PVC pipe and endcaps, but the results were not encouraging. 8" pipe costs $5.00 per foot (20 foot minimum), which isn't bad, but the endcaps are almost $40.00 each. Ouch! 8" PVC pipe will hold about 4.5 gallons (ballpark) per linear foot, so several 6 or 7 foot sections under a bus would be good for fresh water and grey and black water holding tanks.
Back to the drawing board...
Eric von Kleist is offline   Reply With Quote
Old 04-05-2005, 08:29 AM   #2
trx
trx's Avatar
Chassis: Chevy C-60
Engine: 8.2L Turbo Detroit Diesel
Send a message via ICQ to trx
I'm going with old well pressure tanks. They are galvanized steel, I think they hold around 40-50 gallons. These are usually thrown out when homeowners upgrade to the current bladder style tanks. The trick is locating them. They are probably free if you can find them. My parents live next to a dump/recycling center where people just drop stuff off they don't want while others 'go shopping'. My parents like to call it the county mall. Steel recycling places is another place to look. I've got one so far, just waiting for them to go look for a second. They aren't the lightest but shouldn't be an issue for a bus.
trx is offline   Reply With Quote
Old 04-08-2005, 11:11 AM   #3
Water tanks, water heaters, stainless etc.
Talk to your local Plumbers. The frequently replace hot water tanks, and some are still OK, no pinholes rusted through.
If you can get some of these tanks, strip off the outer case, the insulation, and remove all plugs, drains, and the anode.
Rinse the tank well.
Then replace the anode (corrosion protection, and just a few $), and plumb the tank like you would for an under-body installation. Make sure there is a drain to empty the tank!
BTW, with your own water heater, if there is an anode, replace it at the halfway-point of the heater's warrantee date. In other words, if it's an 8-year warrantee, replace the anode at 4-5 years.
Drain/flush the tank once a year, regardless of it's age, this will blow out any iron or other metal flakes that can promote corrosion.
Do this for your house water heater, as well.
I know ONE guy has a water heater in his house, it's STELLITE, the same stuff jet engine nozzles are made of. The manufacture date? 1956!
He's gone through three burners in the damned thing, and it's still going strong. I am SO jealous!!!!!
Which also brings something to mind:
Stainless steel tanks are used in dairies, breweries, etc. Call around, maybe you can find one in a salvage yard, equipment auction, etc.
Put the word out with dealers and friends, maybe they can find you one in their travels.
The tool storage is nice, but where do I put the bed?
Ryan Grimm is offline   Reply With Quote
Old 04-08-2005, 07:24 PM   #4
Water heater tanks also make great BBQs or a shop stove.
busone is offline   Reply With Quote
Old 04-08-2005, 10:48 PM   #5
Firearm's Avatar
Send a message via ICQ to Firearm Send a message via AIM to Firearm
I talked to a plumber and he pointed me to an r/v & camper sales business. They have all kinds of fittings that simply screw together by hand and rolls of gray pvc tubing. It is excellent stuff. Just cut, slide on the fitings, tighten and ta-da, magic.
Firearm is offline   Reply With Quote
Old 04-08-2005, 11:15 PM   #6
When I do my bus I am going to use PEX for all the water lines. I really like how easy it is to work with. The best web source for the pipe and supplies I have found is http://www.pexconnection.com. I have no intrest in the company but have found them useful.
Old 04-09-2005, 08:51 PM   #7
Firearm's Avatar
Yep, that's the stuff. The Flair-it fittings are awesome! Very quick and easy. Did I mention I like quick and easy?
Old 04-13-2005, 09:33 AM   #8
frey2's Avatar
ive got a gray water tank i need to get rid off, has the sensor plugs and the 2" slide valve still attached. It has never been used.
Nicholas Frey
Transportation Chairman
Society of Automotive Engineers
University of South Florida
The first requisite of a good citizen in this republic of ours is that he shall be able and willing to pull his own weight.
-Theodore Roosevelt
frey2 is offline   Reply With Quote
Old 04-13-2005, 09:33 AM   #9
frey2's Avatar
ive got a gray water tank i need to get rid off, has the sensor plugs and the 2" slide valve still attached. It has never been used. 40 gallons
Nicholas Frey
-Theodore Roosevelt
Holding tanks hoser Plumbing, Water and Waste 7 06-28-2021 05:30 PM
Holding tanks GreyEagle Plumbing, Water and Waste 19 06-22-2019 07:42 AM
Holding tanks crazycal Plumbing, Water and Waste 28 10-02-2015 04:26 PM
Holding tanks freezing? lornaschinske Plumbing, Water and Waste 2 06-18-2010 12:51 PM
source for holding tanks? Jody Conversion General Discussions 5 04-26-2006 02:07 PM
