Originally Posted by flattracker
...I first started at Lockheed Missiles & Space (I started out as a technician) and learned how to crimp connectors and solder the Lockheed way. Both ways were used in missiles. I believe that crimping is used exclusively for things going to space now. (solder adds weight while crimping does not)
Phantom and later Hornet Ordnance (with some Motor T and CH53 time in between). I'd like to know how crimping doesn't add weight as there is a component being crimped over the wires being joined.
Definitely no wire nuts or solid wiring in a mobile applications.
In home renovations, the first thing I do when I open an electrical fixture is toss the crappy wire nuts they supplied.
Properly done solder joints...... not cold, not allowed to wick way up the wire, proper amount of heat use of heat sinks as well as the proper flux..... are perfectly fine for many, but not all, mobile applications. I prefer the little insulated crimp caps for most work just because soldering is a pain when not on the bench.
Not sure who mentioned the taps for T'ing in but I would NEVER use one of those in ANY application except a field expedient repair to get someone to a proper repair site.
