Old 10-30-2005, 12:29 PM   #1
captainkf's Avatar
Year: 1985
Engine: 366 propane
Rated Cap: 56
50 amp ac wiring
Can anyone give a detailed outline of how they wired there 50 amp fusebox?
My bus is currently 30 amp and I realize I need more power for changes that are forcast.
What types of umbilical cables have people had success with? Either dual plug that plugs into the rv or a coil up into the rv style with one male plug at the end?
Would it be a good idea to have a few extra breakers and a bigger fuse box to allow for further expansion as needs change or is this unnessisary?
Thanks all. I have found a bunch of info maintaining a system but not installing.
-Richard
captainkf is offline   Reply With Quote
Old 10-30-2005, 08:12 PM   #2
Eric von Kleist's Avatar
Year: 1985
Coachwork: ThomasBuilt
Rated Cap: 60
I strongly recommend the book RV Electrical Systems. It costs in the neighborhood of $20, but is well worth the money spent. Even if you understand wiring, it is an excellent reference book to have on hand, for both 120VAC and 12VDC.
I used #6 - 4 wire flat UF (underground feeder) cable for my umbilical. It is hardwired into my electrical box, and wraps up under the bus (well, theoretically, since I haven't built the mount yet) when not in use. It has a solid copper ground wire, but I am not going to wrap it up a) tightly or b) frequently.
You want to use some kind of "mains breaker" breaker box, not a "mains lug". The mains breaker boxes have a breaker (as the name denotes) between the panel and the supply main. Mains lug boxes just have lugs that you clamp the supply wires down with -- no breaker. That is not good from a safety standpoint. Very not good. Lug boxes can be used as distribution boxes in a system, but should not be used as the box that brings the electricity into the system.
My breaker box has room for 20 breakers. I used 8. I installed the breakers with one empty space between them. That made for a much easier wiring job. Plenty of room to work with, plus I have loads of room for expansion if I ever decide to add any circuits.
It's really important to plan your loads before you do your circuit work. You want to make sure that realisticly anticipated loads on a circuit do not exceed the breaker's capacity. For instance, my water heater takes 10AMPS, and shares a dedicated circuit with ONLY a small 20" florescent light. It is on a 20 AMP breaker, and the wiring is all adequate for at least 20 AMPS.
Wire size is critical, particularly for efficient (and safe) 12VDC systems, but also for safe 120VAC systems. The book mentioned above has good charts on the wire sizes and types that you should/should not use for certain applications.
I used a smaller breaker box for the 12VDC system.
Make sure you ground the AC to the bus chassis!
Eric von Kleist is offline   Reply With Quote
new electric wiring kjones Conversion Tutorials and How-to's 6 05-09-2015 06:36 PM
Can anyone help with re-wiring in NYC? sebjaram Conversion General Discussions 1 09-09-2014 11:40 AM
electrical wiring dieselman69 Conversion General Discussions 3 03-24-2009 12:30 AM
Need Help Wiring Hearse Driver Short-Bus Conversion Projects 2 02-24-2009 06:46 PM
Crown wiring frank-id Conversion Tutorials and How-to's 2 08-10-2005 01:09 PM
