Old 12-21-2017, 11:07 PM   #1
Chassis: e450 super duty
Engine: 7.3l ford powerstroke
7.3l turbo rebuild..
Hey everyone, I purchased a garret gtp38 turbo for $40, so I decided to bring everyone along for the rebuild & upgrade. If you decide to rebuild your turbo insure you know what your have first. You can check by the S/N ***(make sure it is not a ball bearing turbo cause you will regret taking it apart.)
Step 1: Break down, dissemble & clean turbocharger.
(5/16 wrench) Sometimes you may need some heat to remove bolt's.
(make sure you marke "ALL" pieces inline including both housings & center section, so you know were they all go back on the assemble.)
......Remove the Exhaust housing (HOT SIDE)
*Grab a crescent wrench & a socket that fits on you turbine shaft & compressor nut.
*******BE CAREFULLL...!!!!!**** when unscrewing this part some turbo's are reverse thread so >>>>>>lefty loosy righty tighty does not work on turbos...<<<<<..the only way to determine is to look at the compressor wheel & fallow the fins.
*An example..
*Pull shaft out.
*tap off heat shield you may need a chisel.
* Next remove the four nut's use a mallet & expose the inside.. The reason we remove the shaft assembly first is because you do not want to damage the compressor wheel fins while beating off the housing if you are going to reuse it.
* Expose the inner workings of it.
* Next remove the last four bolts...
And look inside..
* remove old seal's, you might need a wire brush..
*Step 2:
Inspection:
***Check all sealing areas & shaft for damage.***
*** Step 3: Clean, Clean, Clean.
***remove seal.
***scrap off excess & clean with either parts cleaner, gasoline, acetone, or whatever you have laying around but scub it until it is new, new, new..
**Scrub the sealing areas Very good, use steel wool if necessary.
***Wash real good.. & dry before it rust's over.
**next back plate & housing..
*** you should also wire wheel the cover if you have one it makes it look puuurty... make you wear glasses anyone that has worked with a wire wheel knows why... WIRE WHEEL EVERYTHING..
Too bee continued...
Blue Sky's
dopamine16 is offline   Reply With Quote
Old 12-21-2017, 11:33 PM   #2
*** But luckily I have access to a sandblast cabinet so I will utilize it, if you do have a sandblaster insure you tape off the shaft for protection.
***After sandblast wire wheel the sealing area to get dirt off, & scotch bright the shaft..
*** Rebuild kits are not all created equal be sure you get a good one.
***nor are compressor wheels.
*** time for a balance, you can always look for your nearest turbo shop to send in your shaft & wheel assembly for a balance it will save you a ton of money...
*** grab your stacks & assemble as such.
***Remove necessary material to balance..
Blue Sky's
Old 12-22-2017, 12:08 AM   #3
Step 4 Port & Polish:
If you are not confident in power tools do not try this cause you will destroy your goods.
Tools of the trade.?
*die grinder & bits. there are different bits for steel & aluminum, so don't work the wrong ones.
***cut a 45 degree angle all the way around being care full not to get too thin, lay it on the material light as a feather & just work it down thin.
After the 45 cut you can get an idea on how much material you are removing. It is easier said than done I know. but If you are brave enough to try it be super care full if you have a new grinding bit.
I been doing this for two years every day & im still scared of new bit's. The power you get from it tho.
***Grind down the rear lip aswell..
*** I used a dermal/extension & sand paper roll for the finish.
*** Here too.
*** for the final finish you flap it by tearing your roll open.
*** Work both sides
*** don't forget.
Blue Sky's
Old 12-22-2017, 12:47 AM   #4
Step 5: Reassemble
***Oil everything, All seals, all bearings & O-rings..
*** Their are no C-clips in center section so we assemble everything on the shaft first.
***The seal gap must face up on (all seals) when assembling, If not oil could seep threw & destroy..
***Add
***Make sure this goes back on properly you can see the bottom is slightly larger for a reason.***
*** Seal gap facing up in the same direction as the on one the turbine shaft, & press it in..
*** Screw back on making sure you use the right ones.
*** Lock tight, ensuring you marks are lined up, on the compressor nut & shaft. from the balancer.
*** Now give it a spin to see for shaft play..
*** line up marks & screw down.. & done.
***screw back on you Exhaust housing after you do whatever you like to it ceramic coat or whatever. Maybe finish it up with some....
Blue Sky's
Old 12-22-2017, 05:53 AM   #5
Outstanding!
Roll Your Own Build Thread
Old 12-22-2017, 08:11 AM   #6
this freakin rocks!!!! I never did my own port N polishing.. that is real art there... fantastic you can do it!!!
do you know if they make upgraded inners for our garrett turbos? I found some injectors that flow about 10% more with the same pulse rate and HPOP pressures. so was thinking if I had a slightly upgraded turbo and those injectors i could gain a little power and still not get into troublw with my EGT's. im pretty sure my 444E turbo is the same one that goes onto your ford 7.3, ..
bigger turbo does no good without more fuel.. more fuel helps most when there is more air!.
what a great thread!!
all this sounds really like I need to send my turbo to your shop for a rebuild / upgrade!!!
Old 12-22-2017, 08:44 AM   #7
Great presentation dopamine!
I am pretty sure I won't be attempting that anytime soon though. How many hours for a job like you just presented? Cost estimate from a shop for that work?
Many thanks again,Merry Xmas,
Old 12-22-2017, 08:50 AM   #8
2kool4skool's Avatar
Very informative, thanks!
Don, Mary and Spooky the cat.
Old 12-22-2017, 09:35 AM   #9
Are you referring to the inner rebuild kit or the center bearing housing itself.? They just make the upgraded rebuild kits but not the housing itslf.? After all I done to my 7.3l my EGT''s stay pretty low, unless I slam it to it than it sky rockets up to 1200 easily but it's transit.
If they are easy to get to & you have to spare $$$ Upgraded injectors.? hell yea why not, I wish I could but I don't dare go that far, ( I am a little beat on the mechanical stuff on my project.) & plus no room to work. Send your turbo on down ill take good care of it.
Blue Sky's
Old 12-22-2017, 09:45 AM   #10
Thank man.
I can do a 7.3l turbo in a couple hours. but for someone who has not done it before.? Definitely an all day thing. Don't let it intimidate you it is pretty simple once you know. I am always here to walk you threw if necessary. cost & labor charges, most shops start at around $4-500 that is around average for a rebuild, if you can find cheaper than jump on it. the porting can average around $100-160. Merry Christmas..
Blue Sky's
