Old 05-16-2016, 07:41 AM   #1
dmattarn's Avatar
Engine: DT466E Allison 3000
Rated Cap: 84 Kids/56 Adults
Advice on wall removal
So I'm ready to remove my walls but they are spot welded to the bottom of the window frame/outside skin. Should I leave this weld intact because it fits in the slot on the bottom of my window frame and prevents water from coming in? What point should I cut it at or do you have an alternative idea?
View from outside
View from inside
Sent from my SM-G900V using Tapatalk
"Once you get it, you got it."
dmattarn is offline   Reply With Quote
Old 05-16-2016, 07:53 AM   #2
I sheared mine off right below the windows.
Old 05-16-2016, 07:54 AM   #3
dmattarn's Avatar
So just below where the window frame is? Or at a point hidden behind the window frame?
Old 05-16-2016, 08:02 AM   #4
Engine: Cat 3126e
Rated Cap: 28
I cut mine off right at the ledge. I think I have a video some where will take a look.
But my skoolie neighbor azuleslight cut and then bent them under and it looks really nice. On my most current video near the end he shows how he did it.
https://youtu.be/OcTQG7f1OP4?t=4m6s
Josiahdr is offline   Reply With Quote
Old 05-16-2016, 08:08 AM   #5
Old 05-16-2016, 08:21 AM   #6
dmattarn's Avatar
Thanks for the advice guys. I really like that tuck, I think I'll try that
Old 05-16-2016, 10:26 AM   #7
Nice steel toe sandals!
dgorila1 is offline   Reply With Quote
Old 05-16-2016, 01:55 PM   #8
Notice my lack of toe nail?
I HAVE steel toes!
Old 05-16-2016, 02:59 PM   #9
I HAVE steel toes!
Makes cleaning them much easier!
