Old 05-21-2018, 08:48 AM   #1
Year: 1994
Engine: DT408 6.7L L6
All Thomas Bus Plans found
So, I found a link to Thomas Bus Companies Floor plan & seating dimensions. Unfortunately each PDF is titled and filed after a particular quote, and not a body style... So, if someone was so inclined they could dig through the massive number of quotes, until they found one that matches the bus they were thinking of buying, and then, *blam* they'd have dimensions...
You might also find some other interesting stuff in there, if you're willing to dig.
www.thomasbusonline.com - /seats/
For example here's a full size RE.
http://www.thomasbusonline.com/seats/102000/102617.pdf
~Alf
My Build Thread!
djdalfaro is offline   Reply With Quote
Old 05-21-2018, 08:59 AM   #2
Year: 1994
Here's a 10 window 1000S body, which is what I'm looking at buying.
http://www.thomasbusonline.com/seats/108000/108626.pdf
~Alf
My Build Thread!
Old 05-21-2018, 09:01 AM   #3
Year: 1994
Please note... this resource is unlikely to last forever... so get them while they're available
~Alf
My Build Thread!
Old 05-21-2018, 12:11 PM   #4
jjhwick119's Avatar
Engine: Dt466e
Rated Cap: 71
http://www.thomasbusonline.com/seats/110000/110773.pdf
this appears to late 90s 11 window like mine.
https://www.skoolie.net/forums/f11/n...tml#post256987
My build thread - Started 3.2.18
jjhwick119 is offline   Reply With Quote
Old 05-21-2018, 12:23 PM   #5
Year: 1994
Does yours have the stretched first window?
I think you should be able to compare the body number on your decal. This image is for a "1110" body.
~Alf
My Build Thread!
Old 05-21-2018, 04:41 PM   #6
jjhwick119's Avatar
Engine: Dt466e
Rated Cap: 71
Yes, i have the stretched front window. I don't know how to find my bus body number
edit - I'm already halfway through my build, but it's still a cool thing to have. And, you have a perfect stencil of your bus. Pretty cool if you want to make any graphics and designing paint jobs as well as getting the dimensions
Old 05-21-2018, 05:34 PM   #7
Year: 1994
At the bottom of the sticker it says
BODY ID: 35904-9622099-C-1000S
96 is the year,
The 1000 is the body type.
IDK what the rest is
~Alf
My Build Thread!
Old 05-21-2018, 05:46 PM   #8
jjhwick119's Avatar
Engine: Dt466e
Rated Cap: 71
Okay, cool. Thank you for that. I'll check next time I'm at the bus.
Thank you for the resource! Takes some digging, but will be helpful for anyone making their plans
Old 05-21-2018, 06:35 PM   #9
Chassis: Saf-T-Liner MVP ER
Thomas describe their bodies by "body section".
So a bus with 14 windows would be "1400", with 11 windows it would be "1100". Each body section has one window.
Their rear engine buses have extra body behind the last window, and that is described in inches.
So ... my 14 window bus would be "1400", but it has an additional 10 inches at the rear so it is 14 + 10", or "1410".
The body ID is a different number. Each bus has a unique identifier.
Steve Bracken
Build Thread
Old 05-21-2018, 06:36 PM   #10
jjhwick119's Avatar
Engine: Dt466e
Rated Cap: 71
Ok, sweet. I have 11 windows with the extra row behind, so I found the right one.
Old 05-30-2018, 02:35 PM   #11
Sasquatters's Avatar
Coachwork: Thomas EF
What is DWG No? Seems as though they are all catagorized under that rather than by window/length/flat nose/dog nose.
Thanks!
Our Blog | Facebook | Instagram
Sasquatters is offline   Reply With Quote
Old 05-30-2018, 03:48 PM   #12
Year: 1994
Thanks!
Yeah, they are categorized by quote number. There is no quick way to find what you are looking for unless someone has already found it!
~Alf
My Build Thread!
Old 05-30-2018, 03:49 PM   #13
In what way do you think would be best or organize them? This is going to take 10s of hours and I only want to do it once.
Old 05-31-2018, 09:02 AM   #14
Year: 1994
So first I see from your signature that you have a 2003 EF. I'm guessing that you have 14 windows from what you said earlier. Lucky for you, from what I've seen the majority of quotes are after 99. I don't know what body style you have. Earlier in the thread I posted a picture of what I believe is probably the easiest way to get the body style.
Just open up a folder and open up a file, and look at the date printed in the lower right hand corner in the "DRN." block. If it's too early, try a folder with a larger number, if it's too late, try a folder with a smaller number.
After that, if you know what you body style you have, instead of counting the windows in the pdf, just scroll down to the details block and it says "Body 1418" or whatever,
Alternatively, if you post your body ID, someone else might come across it and post a link.
Here's an example,
http://www.thomasbusonline.com/seats/212000/212023.pdf
This is a 2003 MVP-EF 1418N body.
~Alf
My Build Thread!
Old 05-31-2018, 11:49 AM   #15
brokedown's Avatar
I dug through this for a little bit and wow its not easy to find anything!
Old 05-31-2018, 12:07 PM   #16
Year: 1994
This is correct. But it does give a nice drawing to help design with if/when you do find it.
~Alf
My Build Thread!
Old 06-01-2018, 08:48 AM   #17
Here's an example,
I am not trying to find ours. I downloaded them ALL and I want to organize them nicely and host them on our website so that it is easier to find what people are looking for. I am asking, what is the best way to categorize these.
Old 06-01-2018, 10:28 AM   #18
brokedown's Avatar
The body id is the part you want to index by. I was thinking about trying to catalog them using ocr but if you beat me to it then that's less work for me!
Old 06-01-2018, 10:30 AM   #19
I was thinking along the lines of window number, wheel chair access, dognose/flatnose, etc. maybe I won't do it. This seems complicated and I'm quite busy.
Old 09-24-2018, 06:14 PM   #20
Chassis: Ford E450
Found the needle in the haystack!!!
for anyone else that has a 2003 E-450 with 051MS body (5 window with handicap access on passenger side) the plan is
http://www.thomasbusonline.com/seats/211000/211187.pdf
2planker is offline   Reply With Quote
