03-25-2023, 01:47 PM
#501
Year: 2006
Chassis: IC CE300 (PB105)
Originally Posted by WiredForStereo
For transmissions, Allison makes sells their own which I think may be made by... I forget. I
Allison Transynd is what I think you're referring to. I believe its made by Castol Fleetguard makes a variant of it too that's supposedly Allison approved.
03-25-2023, 07:19 PM
#502
Traveling
Allison Transynd is correct.
03-25-2023, 08:57 PM
#503
Chassis: TC2000, 40' MPV
Rated Cap: U/K
Amazon has it for around $60/gal
03-26-2023, 06:18 AM
#504
from what ive seen any of the TES-295 rated fluids seem to be pretty equal.. I use transynd brand in my allison 1000, my MT643 and AT540 still have regular fluid in them..
ive used quite a few Amsoil products over the years and have had no issues with them so I wouldnt hesitate to use the amsoil TES-295 trans fluid in the allisons..
03-28-2023, 01:36 AM
#505
Do not post personal info
Please do not post others’ personal information, particularly without their consent. This is a (very) public forum.
03-28-2023, 07:01 PM
#506
Traveling
Sorry if there were any issues, he literally told me I could share his information.
03-30-2023, 08:48 AM
#507
I've been working with the guy that does unlocks for a few years, and we've done around 30 of them together in that time. Highly recommended upgrade if it applies to you.
As far as his personal info, there's a difference between privately sharing an email address and posting a person's real name. Because of the highly sensitive nature of these modifications, I have switched to collecting payment for him rather than putting people directly in contact with him. The belt is getting tighter and nobody wants any trouble.
03-30-2023, 05:20 PM
#508
Engine: 345 international V-8
After a month or so of driving with 6th gear unlocked I am still pleased to have it unlocked. However have noticed a few things, around here it is rolling hills and a few steep grades up to 8%. I find it is always hunting between 5th and 6th unless it is flat land and over 65mph. So have been putting it in 5th and leaving it there for local driving. Not to thrilled with that.
So tried the "mode" button. Nice, so much better, stays in 6th unless the grade gets steep. And no more revving to the rev limiter then shifting. Even though the mode button is for economy it really seems to climb at least small grades better, feels like the engine is more in it's power band rather then defueling close to the rev limiter. So for those who do unlock try the mode button, for me that makes a real difference.
03-31-2023, 08:29 AM
#509
I always put mine in economy mode. It seems to shift up a little earlier but holds higher gears longer unless I'm actually pushing the pedal down. I wish it could set as the default instead of having to push the button every time.
03-31-2023, 08:30 AM
#510
you dont want to hold too long... my allison liked to hold and labored the engine.. 6 to 5 goes up and down qwuite a bit on rolling hills.. I just run mine in a lower gear when im in rolling hills and then go back to auto when its more flat.. im also over-geared in the rear.. my bus could go 85 in 5th if i really wanted it to.. if your rear gear is tall it will hunt a lot.. you can hold it in 6th longer with ECON mode but watch your EGT you can run em up pretty easily..
02-07-2024, 08:08 PM
#511
Coachwork: IC
wired.....you no longer accept PM's? I a interested in unlocking 6th on my md3060
02-08-2024, 05:24 AM
#512
What year is yours? I've figured out how to unlock the older WTEC IIs
02-08-2024, 07:12 AM
#513
Coachwork: IC
Build date 2003
02-08-2024, 07:39 AM
#514
Rated Cap: U/K
While you're here...I have a 98 bluebird with a b300 trans. I know nothing about the version, wytec 2 or 3 ? I'd like to get 6th unlocked although it's no rush. What do you think?
02-09-2024, 09:34 AM
#515
Coachwork: American Fire & Rescue
Chassis: IH 4900
Engine: DT466 250hp P-pump
!!! Do tell! -If it’s something you can share.
I have 6th gear by using the calibration from a similar truck; but my truck did seem to shift a little better with the original calibration.
But if there’s a way to have the best of both worlds…
03-10-2024, 09:36 PM
#516
Coachwork: IC
found a guy in Va that unlocks for $400....supposed to get my TCM back this week,will report back!
03-19-2024, 08:24 AM
#517
Coachwork: IC
Engine: T444e Rear Engine
2004 ICBus MD3060 unlock
Hey! looking to get my 3060's sixth gear enabled. I hear tell of some folks that can do it, I just don't know any of them. Any help would be great as it doesn't seem International will be giving me an OEM letter for Allison.
03-20-2024, 05:36 PM
#518
3 or 4 pages back you will find his contact info... the guy that can help you out!
04-02-2024, 06:11 PM
#519
Coachwork: IC
PM if you need Chris' contact info
