Old 04-18-2015, 06:37 PM   #1
Chassis: E350
Engine: Ford 7.3 Powerstroke
Rated Cap: 16
are the red/yellow light suppose to work?
My bus has the standard red/yellow in front and back, they do not come on when I hit the switch. Do the bus companys disable these when they sell? I have moved the red to the rear and yellow to the front, so it should be legal to have them working, ????
Dragrace is offline   Reply With Quote
Old 04-18-2015, 08:53 PM   #2
Check with your local Dept of Motor Vehicle . Don't ask a cop because they may not know but the DMV will have the latest
steveoutdoorrec is offline   Reply With Quote
Old 04-18-2015, 09:38 PM   #3
Engine: TE 444
Rated Cap: 12
you can hook them up to the turn signals, brake lights, running lights, but you can not have them flash like they do on school buses
the school district I bought my bus from disconnected them and painted them black, said Ohio required them to do that
Old 04-18-2015, 10:07 PM   #4
Mine are all yellow but they flash in a wig-wag pattern, that's the issue.
dond is offline   Reply With Quote
Old 04-18-2015, 10:43 PM   #5
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
I move yellow to the front and red to the back, but they are disabled.
I'm hungry!
You Gotta Let Me Fly
Old 04-19-2015, 04:57 AM   #6
In TN you are fine, Minnesota... Dunno
Here biggest issue was NO red lights facing forward (same as NO blue lights) so I moved mine, and yes mine still work, I use them same time as the hazards
No issues
Old 04-19-2015, 09:52 AM   #7
Different jurisdictions have different rules.
In WA state, if the bus is not a school bus then they need to be disabled.
I have seen some where people have put headlights, fog lights, or other clear type lights in place so they can be used for lighting up the yard. If you do something like that they need to be covered while on the road if they are up front.
Four flood lights can light up an impressive amount of real estate at night.
Old 04-20-2015, 06:36 PM   #8
Chassis: E350
Rated Cap: 16
So, it looks like I have three tail light mini lights arcoss the top in back, so I can convert these to 4 large high tail lights very easily. same in front, but I don't really want 4 large yellow running lights on all the time in front. Maybe I'll get a good idea somewhere.???? I would really like to have them all working as emergency flashers, but I don't know how they were disabled.
Old 04-20-2015, 09:55 PM   #9
Engine: TE 444
Rated Cap: 12
the 3 lights in the middle of the roof on the front and back have to stay as they are, they actually mean something, called ID lights, means your vehicle is over 6 and a half feet wide
Old 04-21-2015, 10:21 AM   #10
Chassis: E350
Rated Cap: 16
Thanks, Kubla, I didn't know that. What I had in mind was splicing the larger lights into that wireing harness. If I was ambitious, I would want to hook up turn signals to the top large lights also, but that involves fishing for the right wireing.
Old 05-21-2015, 09:38 AM   #11
Coachwork: GMC
Chassis: G3500 Vandura
Engine: General Motors 5.7L 350 V8
Rated Cap: 17
I was wondering this as well for Texas. We will need to do something for when we make stops. Maybe just hazard lights and we could connect some of the lights to those.
Our stop sign on the side does not currently do anything which is another to-do list item. The stop sign itself is missing completely, but we may need to have something other that anyway to not break any road laws. Something like "WATCH FOR CHILDREN" would do rather than "SLOW CHILDREN" Lol
mobile New Orleans style snoball stand conversion
https://en.m.wikipedia.org/wiki/Sno-ball
The SnoBall Effect is offline   Reply With Quote
