Old 02-28-2016, 03:08 PM   #51
Originally Posted by gizmoq View Post
I thought this thru when building my bathroom(24"x36"). I designed it for me and mine fam (we're all small framed). Went so far as to write an instruction notice for outside the door. Bottom line, if you don't want to sit, piss somewhere else.
I'm trying to find the super sized like button for this reply.
Deezl Smoke is offline   Reply With Quote
Old 02-28-2016, 10:13 PM   #52
gizmoq's Avatar
Year: 1978
Chassis: Lifeguard
Engine: 366 Chevy
hehe
The more I do, the more I find needs done.
____________________________________
Build Thread - ET - ELWOOD Transporter
gizmoq is offline   Reply With Quote
Old 02-28-2016, 10:45 PM   #53
Originally Posted by charles_m View Post
Dont piss in your greywater tank, that's not what they're for.
urine is sterile. it is safe to put into a grey tank. Just dont be an idiot like some and dump your grey water on the ground...
keiffith is offline   Reply With Quote
Old 03-05-2016, 08:18 PM   #54
Skoolydoo's Avatar
Rated Cap: 2+1
Well I have been doing so research, so for you manly men that can't or won't sit to pee
Then here you go
Male Urinal | Advantage Urinal Systems
You can run the hose any where your little heart desires..just saying
Don and Ellen
Plus one fuzzy faced kid (Poopcee)
Skoolydoo is offline   Reply With Quote
Old 03-06-2016, 05:45 PM   #55
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
I think I'll pass on that urinal system. A surplus 5 gal water jug will fill the bill nicely and won't cost much. Plus, the hole is a big enough target.
Military Water Can
Old 03-06-2016, 06:05 PM   #56
Skoolydoo's Avatar
Rated Cap: 2+1
The water can works also
Don and Ellen
Old 03-25-2016, 06:27 PM   #57
Chassis: international
Rated Cap: 71
Is the cost about the same? I mean The one toile is $1000, ($995.00)
On a not BROKE budget and NOT on a MONEY NOT A PROBLEM budget
After you build in for the black water tank and all the supplies to make everything is the cost Higher / Lower same?
Thank you.
livinthelife is offline   Reply With Quote
Old 03-25-2016, 09:48 PM   #58
my toilet was $200.00, tank was about $270.00 , maybe $20.00 for black 3 inch pipe and fittings. just a couple feet of pex pipe to hook up the water supply. I mounted the tank with steel from a bed frame, wasn't hard to install.
Old 03-25-2016, 10:06 PM   #59
Rated Cap: 71
Wow. For some reason I was thinking it would be closer to the same price and I'm sure you could if you go high end stuff (seat warmer).
Old 03-25-2016, 11:35 PM   #60
Coachwork: IC
Chassis: CE300
Rated Cap: 32
I've seen tanks for $100, porcelain RV toilets for $150.
Roll Your Own Build Thread
bathroom
