I use 1.5-2" angle and weld up a rectangle the battery(ies) will fit in and weld a piece of allthread on both ends where each battery will set and a hold down strap made of flat plate or angle with wing nuts to hold it down the you can mount that anywhere you want by brackets or hang using larger longer all thread at the corners. I would say browse Google for semi truck battery holddown's or battery boxes and get an idea of how different mounting styles work if you can weld you can make pretty much anything
Trust in the Lord with all thine heart; and lean not unto thine own understanding. Proverbs 3:5
In all thy ways acknowledge him, and he shall direct thy paths. Proverbs 3:6
