my bus came from texas and no EBPV.. I live in ohio... I dont have a block heater but I have great batteries, 8 good glow plugs and plug relay.. I start the bus easily down to minus 10.. I let it idle a couople minutes in which the 444E auto kicks to 900 RPM after the oil pressure raises to above 25 for about 5 seconds.. then you can program CAP into your computer in which after 5 minutes of no pedal activity and in neutral the engine will self idle up to 1400 RPM and then back down as it reaches near 175 degrees f coolant...
literally though I rarely idle it long enough when I start out for CAP to engage.. the 900 for a minute or 2 then I take off... once I see about 100-105 I kick the heater fans on and as I get down the hoghway it warms quickly.. I see no need for the EBPV.. maybe it warms quicker? I dont know but seems like mine warms up pretty good esp if I get on the freeway... takes a little longer in stop N go with all my heaters on..
" I see no need for the EBPV.. maybe it warms quicker?" It's not good to push (VERY COLD) boost to a cold engine so this not only helps it to warm up but keeps you from having boost till the engine is up to a safe temp for it.
It can be annoying but if you are like me and cut off the exhaust, when the EBPV is closed man does the exhaust get so much louder, sounds like a jet. I have't hacked off the exhaust on the bus yet but I do to every F series 7.3 I've owned and just had the down pipe that came out near the trans bell housing. No muffler gives slight lower EGTs.
The EBPV does cause a very minor bit of restriction so the theory is you will get a little more air flow with it deleted.
Yeah they leak, but they are easy to rebuild (I have a video on YT rebuilding one), kit cost under $100 for what little it needs. So easy my 7 year old did most of the reassembly.
Pulling the turbo will go way easier on a bus than the trucks I've pulled turbos on that is for sure.
I don't know if I will wire mine up in the bus for a brake, my trans has a retarder on it and that does a pretty decent job.
Hey Chris, have you ever changed out the out put shaft seal on a MD3060? I'm going to have to do mine and the blame pinion shaft seal on the rear as well. Atleast that is all the leaks I have to deal with.
Yall have a good day!
