Old 12-13-2019, 10:54 PM   #1
TheHubbardBus's Avatar
Coachwork: IC / Amtran
Chassis: CE300
Engine: International T444e
Rated Cap: 23
Bendix has info on EVERYTHING for air brakes online
Included as an attachment is a teaser.
But if you want service docs, manuals, tech bulletins, training materials... for pretty much any Bendix component or system, they're all here:
https://www.bendix.com/en/servicessu...y/doclib_1.jsp
Not only can you find docs on pretty much anything, on the left side of the page above, parts cross-refs, diagnostic aids, training materials, etc. It's a goldmine!
Go away. 'Baitin.
Our Build: Mr. Beefy
Old 12-14-2019, 07:57 AM   #2
AND!!
when I had trouble with a compressor I called bendix tech support and the guy gave me help and all kinds of part numbers to cross over for compressors that would fit my bus...
did the same with my Superior bus.. my comoressor was leaking at the shaft seal.. called bendix and the guy told me my compressor hads replaceable seals, gave me the part numbers.. and off i went.. fixed like a champ...
Old 12-14-2019, 03:12 PM   #3
Marceps's Avatar
Chassis: Saf-T-Liner MVP ER
Engine: CAT 3126
Thumbs up
Nice. Thank you for sharing.
For anyone with an MVP-ER like mine, here are the relevant documents for your bus:
Code:
AD-9 Air Dryer (OPTIONAL)
├── BW1715_US_007.pdf
├── BW2088_US_001.pdf
├── SD-08-2412_US_008.pdf
├── TCH-008-030a.pdf
└── TCH-008-041.pdf
ASA-5 Automatic Slack Adjuster
├── BW1641_with_instructions.pdf
├── SD-05-1269_US_006.pdf
└── TCH-005-013b.pdf
DV-2 Automatic Reservoir Drain Valve
└── SD-03-2501_US_008.pdf
... and for anyone running a manufacturing company, this is how you win over the worthwhile customers. Props to Bendix. I will never again crack a crude joke regarding their corporate name.
Marceps is offline   Reply With Quote
