Old 03-12-2017, 06:19 PM   #1
Coachwork: Thomas Saf-T-Liner MVP ER
Engine: 7.2L CAT
Rated Cap: 37 feet, flat nose, RE
Best way to remove rubber floor from steel surface?
Hello everyone!
I'm trying to remove the rubber floor but it's taking me forever. I think it's because it's stuck onto only the steel floor of the bus. I was thinking a putty knife would be the best tool but it's not quick at all
Does anyone have better/quicker suggestions please?
Thank you
davidrheal is offline   Reply With Quote
Old 03-12-2017, 06:28 PM   #2
Njsurf73's Avatar
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
Originally Posted by davidrheal View Post
Hello everyone!
Thank you
Look into a roof rake. Or go to Sherwin Williams and get a pole scraper that screws on to a paint pole or broom handle. It is heavier duty than a regular putty knife and has a chisel edge
Old 03-12-2017, 07:20 PM   #3
Roadrunner's Avatar
Chassis: TC 2000
Engine: 5.9
Rated Cap: 83
I used a pole air chisel thing. I don't remember the exact name of it. It came from Harbor Freight. It took the rubber right up in large pieces. There are pics of it on my build thread entitled 'pics of my build so far' or something similar. I don't know if you have HF stores there but you could get one on the net. It runs on compressed air. It sure made it a lot easier and faster. I think it was $49.00 US. Good luck.
Hopeless Busaholic!
Roadrunner is offline   Reply With Quote
Old 03-16-2017, 04:47 PM   #4
Chassis: Saf-T-Liner MVP ER
Engine: CAT 3126b Rotella-Chugger
I used one of these, sometimes called a "johnson bar," it is basically a floor scraper but made of heavy steel and though it is exhausting to use after awhile, its heft allows you to get good momentum behind it, more effective at pulling the floor up than a small scraper. It is a good workout!
My steel floor was super rusty causing the adhesive to fail in some spots, so the rubber came up in sheets. The one advantage of having a rusty floor!
porkchopsandwiches is offline   Reply With Quote
Old 03-20-2017, 02:24 PM   #5
Whims and Wishes's Avatar
Coachwork: Van Hool
Chassis: T2140
Engine: Cummins M11+ 450hp
Send a message via AIM to Whims and Wishes Send a message via MSN to Whims and Wishes
Hello everyone!
Thank you
We used a heat gun to warm the rubber floor, then scraped it up. It came up reasonably easy at that point.
Whims and Wishes is offline   Reply With Quote
Old 03-20-2017, 02:33 PM   #6
Robin97396's Avatar
I second the heat application to loosen the glue. Heat lamps can be hung over tougher areas.
Good luck.
Robin
Nobody's Business
