Old 02-12-2019, 11:44 AM   #1
EtownAcres's Avatar
Year: 95
Bluebird interior bottom panels.
Any suggestions on removing these bottom panels? They aren't riveted in with a normal rivet. I'd assume the grinder is gonna get some action soon but wanted to see if you guys have any tips.
Thanks
File Type: jpg 51757575_398691000693179_825764177699143680_n.jpg (171.4 KB, 12 views)
EtownAcres is offline   Reply With Quote
Old 02-12-2019, 11:51 AM   #2
Njsurf73's Avatar
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
Thanks
They are solid rivets, instead of blind or "pop" rivets. They are secured with a hammer and swage block to mushroom the ends. You will have luck with grinding the heads off, but may still need to drill or drive some out.
Old 02-12-2019, 12:10 PM   #3
EtownAcres's Avatar
Year: 95
Yeah, I was afraid the grinder was about to get some action. I used the grinder on all the top panels before I found that an air chisel was the best way to remove them. I hate griding...
Old 02-12-2019, 12:13 PM   #4
TJones's Avatar
Chassis: CS RE
Engine: ISC 8.3 L 260 hp
That is the seat rail. The general consensus is it should be left in place as it joins the wall to the floor. The are many posts on this topic.
Ted
Old 02-12-2019, 12:27 PM   #5
EtownAcres's Avatar
Year: 95
Thanks, I'm fairly new to forum life. I knew it was the rail but wasn't really sure how to search it for results on the topic.
I'll read some post on it, maybe it'll enlighten me on why leaving it is a good idea. Right now it's in the way. I'm open to learning why it's important though.
Ted
Old 02-12-2019, 12:35 PM   #6
EtownAcres's Avatar
Year: 95
Good enough for me to leave it. I'm actually relieved. lol. I wasn't looking forward to that grinder. I'll just need to figure out some work arounds.
Thanks guys
Link that changed my mind. below
http://www.skoolie.net/forums/f13/ch...ma-9225-2.html
Old 02-12-2019, 12:50 PM   #7
They are part of the structural integrity of the body, DO NOT REMOVE them.
