Old 06-26-2018, 10:21 AM   #21
firebuild's Avatar
Coachwork: Lewis
Chassis: Ford E350
Engine: 7.3L Diesel
Originally Posted by cycle61 View Post
I don't think that would be a good idea to install into a bus. It looks heavy and fragile, and I would be concerned that even if you got the base connected firmly to the bus, an accident would send a lot of old lumber airborne towards the back of your head.
It's actually not particularly heavy or fragile. It's a big hollow box. And I honestly don't see what the difference would be between installing this or, say, a refrigerator. I've also seen people build closets about this size, which they of course then have to attach to the bus. I don't really see what difference the age of the lumber is going to make in a crash.
firebuild is offline   Reply With Quote
Old 06-26-2018, 10:37 AM   #22
Year: 1954
Coachwork: wayne
Engine: cummins 12 valve
The armoire...
Okay, I think L brackets for the bottom will work. The leg portion of that looks pretty thick and study. use four L brackets for the bottom, we will start there.
The L bracket should be four inches long on each leg, or five inches would be even better. We, you, are going to be using mostly 1/4 bolts for this project. You will probably need someone else to help you when we do the floor bolts.
You might also use four wood screws and they are going to be bigish in the diameter and about 1 1/4" long.
use grade five hardware. for this grade 8 is useless over kill and grade 2 is just junk.
Look up on the internet how to recognize grade 2, grade 5 and grade 8 bolts. you want the stuff with three hash marks.
Let me know if you prefer the metric system and we can work that way too.
You will put two 1/4" bolts in the floor for each L bracket. Use a 5/16" to drill all the holes we will be making.
we are going to attach all the L brackets to the Armoire first. Then attach to floor, and then we will do top/ side last.
are you with me so far?
Try to find L brackets that have 1/4" holes, do not go any shorter than 4" longer we can work with.
KEEP ALL RECEIPTS. you will return all extra hard ware to keep the costs down and we may have a false start or two. Working remote can be tough todo.
I think the holes should be all in a row, some L brackets have the holes kind of in a zig zag pattern.
I think the L brackets should be about 1/8' thick metal. Steel.
we will put all four brackets inside, so you will have to work in the space where drawer goes.. tight confines.
Do you think you can work in that tight spot? If not we will rethink what we do, Is that okay for you?
How are we so far?
Old 06-26-2018, 10:41 AM   #23
firebuild's Avatar
Coachwork: Lewis
Chassis: Ford E350
Engine: 7.3L Diesel
Yes, I think I can. Thank you, this is EXACTLY what I needed!
Old 06-26-2018, 10:41 AM   #24
I'd suggest fastening it to any part of the bus it will touch.....floor, wall, etc. Preferably in as many places as possible. Since this thing is going to be right behind your seat, I'd also put a some cargo tie-down rings along the edges (top and bottom) and use cargo straps to strap that sucker in while you're moving. Easy enough to unhook when you've settled in at your campsite. Bolt the tie down rings to the ribs, ideally.
Old 06-26-2018, 10:42 AM   #25
Year: 1954
Coachwork: wayne
can we have...
a picture of the space this is going to sit? Might help form a plan for attachment of upper area of armoire. did i spell that wrong?
Old 06-26-2018, 10:46 AM   #26
Chassis: 3000RE
Engine: T444E w/ MT643
Rated Cap: 84 pass, 40'
I agree with this. My motto is "belt and suspenders!" I would definitely also attach to the ceiling and wall just as a build in closet would be. You could remove the legs of the armoire or attach extra wood to the bottom to be able to afix it even more firmly through the floor.
2martins is offline   Reply With Quote
Old 06-26-2018, 10:51 AM   #27
firebuild's Avatar
Coachwork: Lewis
Chassis: Ford E350
Engine: 7.3L Diesel
I'll get a picture later today.
My plan was to have horizontal e-track down the entire wall, and use the cargo tie-downs that clip in to the track. My reasoning was that it would give me the flexibility to tie down pretty much anything at any point along the bus wall. In that case, it would be the track that is bolted to the vehicle. I was basing this on what I've seen in 18 wheelers that haul a lot of furniture. Does anyone use this system, and is there any reason why it wouldn't work?
Old 06-26-2018, 10:55 AM   #28
Had to look it up, as I didn't know what a horizontal e-track was. Looks perfect, to me. Wish I had known about such a system myself!
Old 06-26-2018, 10:56 AM   #29
firebuild's Avatar
Coachwork: Lewis
Chassis: Ford E350
Engine: 7.3L Diesel
It's nice to know I know SOMETHING! Lol.
Old 06-26-2018, 11:19 AM   #30
Anti tip straps similar to these would help.
Old 06-26-2018, 02:44 PM   #31
Chassis: IH
I *LOVE* E-track. i have this on ... well ... *ALL* my trailers and it is infinitely useful for securing stuff. I have probably over 100 straps for it (and they come in 12', 16', and 20' lengths, for those who may need to secure larger items). I don't (yet) have any in my bus, but I do have a few pieces of E-track scraps I could cut and install. I used 1/4" bolts in my enclosed trailer and none have failed yet - and I have a tendency to really crank down my straps if needed (not so much with furniture, though). Anything strapped in will "ride like a Cadillac" and I am confident it will remain where it's supposed to even in a crash.
Use 1/4" steel rivets if you need to install in a place where you can't put a nut. Don't use aluminum rivets, as you *NEED* the extra strength of steel, as well as preventing future electrolysis between dissimilar metals.
Old 06-27-2018, 05:57 PM   #32
Use what you got!
My 10cents here:
Use what you already have!
I cut off the seat backs.
I used the existing bus seat brackets along with original nuts and bolts to fasten the seat brackets to the floor joists. I used the original bus seat clamps and original huge wood screws to fasten the couch to the seat brackets. Same with the club chair. On both pieces of furniture I used the original holes and nuts/bolts for seatbelts too.
Under the couch is sliding storage bins. Under the club chair is the fresh water tank. Which has an access panel outside.
All other furniture has the same bolted to the original floor holes and joists.
Safety first!
JocelynDavis is offline   Reply With Quote
Old 06-28-2018, 02:22 AM   #33
firebuild's Avatar
Coachwork: Lewis
Chassis: Ford E350
Engine: 7.3L Diesel
That does seem like the easiest way to go, if things line up right! I had to switch gears for a bit as I had a little painting crew available. I have such a compressed timeline for getting everything done I have to take help whenever I can get it, so we have been working on Buster's exterior. I will get back to the bolt-down in the next coupe of days.
Old 06-28-2018, 08:03 AM   #34
Year: 1954
Coachwork: wayne
we will be here when you come back
we'll get back to it,
when you can do it.
waiting just for you
then we'll see what you can do.
Take some time to mull
how to drill some holes.
ponder nuts and bolts
a new idea can be a jolt.
I'll talk in a day or so
when we finish we'll have some joe.
william
Old 06-28-2018, 04:42 PM   #35
firebuild's Avatar
Coachwork: Lewis
Chassis: Ford E350
Engine: 7.3L Diesel
William, your last name wouldn't happen to be "Shakespear," would it? LOL
