Old 06-19-2011, 11:21 AM   #1
Coachwork: blue bird
Chassis: 3500
Engine: 5.6
Rated Cap: 16
brake & turn lights
i really love my bus but want to convert the top old flashers to brake and turn in back and will use all amber in front as turn signals. i hope someone may have done this and have some tips for me...thanx
chris white is offline   Reply With Quote
Old 06-20-2011, 07:52 AM   #2
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Re: brake & turn lights
Do some checking, I think there are some regulations about how high brake/turn light can be. I think it was on this forum.
Old 06-20-2011, 08:16 AM   #3
GreyEagle's Avatar
TRUCKS, BUSES, MPVs: FEDERAL LIGHTING EQUIPMENT LOCATION REQUIREMENTS
NO MORE THAN 72 INCHES ABOVE THGE GROUND
Link http://www.arenco.ca/normes.pdf
GreyEagle
Roll - On...
GreyEagle is offline   Reply With Quote
Old 06-20-2011, 11:05 AM   #4
lornaschinske's Avatar
Rated Cap: 89
Where did you see the "maximum" height? I have had the same chart for years (different source). I understood that those were the legal requirements. I have noticed that a lot of the semi trucks are looking more like "christmas trees" due to all the lights on them. Not only are the getting carried away with the side marker lights but I have noticed that an increasing number of the cabs are installing upper brake/turn lights towards the upper rear parts of their cabs. We will use one set of the old flashers as a "docking light (a 75Watt docking light... then I want to go find that yo-yo who left HIS sticks-n-staples RV's docking light on for hours late one night!!) and standard stop/turn/ parking light bulbs on the outer rear (red cover) and a turn or parking/turn bulb in the outer front (amber cover). NOT the original 75W bulbs!
http://icsw.nhtsa.gov/cars/rules/standards/conspicuity/
Fulltime since 2006
Old 06-20-2011, 12:20 PM   #5
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
you could probably hook the ones up top to work WITH the current ones on the back of the bus but you cant unhook the current ones if thats what you mean.
Old 06-20-2011, 03:52 PM   #6
GreyEagle's Avatar
very last column on the right, under trucks and buses.. top 4th page down.
TRUCKS, BUSES, MPVs: (continued)
BASIC EQUIPMENT REQUIRED ON ALL TRUCKS, BUSES & MPVs
DESCRIPTION MANDATORY REQUIREMENTS
Area Equipment (SAE Lens Coding) Functional Purpose Quantity Color Location
Height mm (in.) from the ground 15 - 72 inches / 380-1830 mm
Stop Lamps (S) Indicate braking Minimum 2
Red On the rear - symmetrical - as far apart as practicable
the xmas tree lights are all marker lights on the big trucks......
GreyEagle
Roll - On...
Old 06-20-2011, 05:47 PM   #7
Rated Cap: 89
It does not say MAXIMUM height, just gives a range. I will have the required lights placed in the specified placement ranges... and some extras. Doesn't matter. I will do our extra lights as planned. If it turns out to be a problem in any state we title/tag in, then I will simply remove the bulb.
Fulltime since 2006
Old 06-20-2011, 06:58 PM   #8
GreyEagle's Avatar
Height mm (in.)
from the ground
(no lower than 380mmm - no higher than 1830 mm)
(no lower than 15 inches no higher than -72
from the ground )
Good luck with your build,......... You are way ahead of me I don't even have one yet...
GreyEagle
Roll - On...
Old 06-20-2011, 07:16 PM   #9
Rated Cap: 89
I won't go round and round with you. I have tagged/titled a former commercial vehicle as a recreational vehicle before and I already know that many of the things that you guys think apply, do not apply to a recreational vehicle (must be tagged/titled as such). If I have a problem when I put it out on the road, I will post that. Until then, I will do what I want to the lights. I will have the MANDITORY LIGHTS. I will also have the extra light. The requirements do not address that. As far as I know (based on observation and reading OTHER forums) I can put OTHER additional lights on the bus.
Fulltime since 2006
Old 06-20-2011, 07:25 PM   #10
GreyEagle's Avatar
I do not want to go (around) as you call it .......was only trying to help a fellow skoolie out.... It says he, she, it did not say it was mandatory...
It's printed in bold letters at the top the page....MANDATORY REQUIREMENTS
I don't care what you do with your lights, it's your bus, your lights, have fun with it.....
Just wish I was out there too.....
LIFE'S A TRIP, .........TAKE ONE
GreyEagle
Roll - On...
Brake lights don't work! Tool Amour Skoolie Conversion Projects 4 08-14-2013 12:41 PM
air brake 101...or how to fix/diagnois a stuck brake issue bansil Conversion General Discussions 16 06-28-2012 02:28 PM
Running Lights and tail lights not working bapos Alternative Fuels | Electric, Propane, Wood Gasification, etc. 2 12-14-2011 11:32 AM
Tail lights,running lights not working putterspitt Conversion General Discussions 2 10-12-2010 05:19 PM
Old Skool's Got brake lights !!! KaptnKAOS Conversion General Discussions 16 06-26-2007 02:41 AM
