Old 08-18-2008, 06:34 PM   #11
Year: 1966
Coachwork: supierior
Chassis: Chevy C60
Engine: Chevy 454
Rated Cap: 10
Re: Brake Line leak
first of do not use feral couplings to patch brake lines, this is actually illigal. the amount of preasure in a power brake system can exceed 1000-3000 psi at the cylinders and those feral couplings can come off. if you do a coupling you must use flares and proper fittings. second the farthest wheel from the master cylinder isnt always the right rear, mine its the left rear that has the longest distanst from the master cylinders. Third if you are having trouble getting a wrench on it try a rachet and socket, you dont have to make bleeders that tight to keep them from leaking you make them tight to keeep them from comeing loose. so you dont have to crank down on them inbetween pumpings. And if a rachet dosnt work take a reagular wreanch or an extra long one and heat it up with a tourch and bend it cut it to do what you want then hang it on the wall and watch people look in amesment at this wierd wrench you have
junkyardkid is offline   Reply With Quote
Old 08-18-2008, 07:42 PM   #12
the_experience03's Avatar
Re: Brake Line leak
Holy old thread, Batman! And I'm with you on the left rear being the furthest away (at least on my beloved Toyota), but that is not normally the case.
1997 Ford B-800 brake line repair tomas_maly Conversion General Discussions 18 09-24-2013 05:21 AM
Brake line leak? Seeria Mechanical and Drivetrains 3 06-01-2011 03:18 PM
Leak in Air Brake - How to test? kirkndopp Conversion General Discussions 8 05-15-2010 11:22 AM
Replacing air line help. <brake lines> abdabbs Mechanical and Drivetrains 11 04-01-2009 03:28 PM
air brake line weird ends cant seem to find racetearoffs Mechanical and Drivetrains 3 04-23-2006 01:55 PM
