Old 06-28-2009, 05:33 AM   #1
nyrockingchairs's Avatar
brake pad and caliper replacement
Hello all,
I have a 1988 GMC S6000 full size with hydraulic brakes. My left front caliper has frozen and I need to replace both the caliper and pads.
I got the wheel off but cannot figure out how the caliper comes off. Can someone help me out here? Thanks.
-Rich
1988 Chevrolet S6000 8.2L Detroit Diesel
nyrockingchairs is offline   Reply With Quote
Old 06-28-2009, 08:18 AM   #2
Re: brake pad and caliper replacement
The only bolts I see are the 4 nuts holding the entire back plate and hub assembly on. The only thing I see on the caliper itself is the bleed nut.
'91 Bluebird Disc Brake Caliper wheeler Mechanical and Drivetrains 16 09-13-2012 08:07 AM
air brake 101...or how to fix/diagnois a stuck brake issue bansil Conversion General Discussions 16 06-28-2012 02:28 PM
Carburator replacement 81'gas 109lincoln Conversion General Discussions 5 04-17-2012 01:56 PM
Rear Caliper Siezed... HELP PoconoBoozer Conversion General Discussions 1 06-01-2009 10:58 AM
How to remove a Bendix Caliper off the bus? asnowsquall Everything Else | General Skoolie Discussions 2 10-02-2006 09:37 PM
