Old 01-29-2009, 11:43 AM   #1
Coachwork: blue bird
Chassis: chevy
Engine: 366
Building a black water tank and shower base.
Anybody got any good ideas about building either a black water tank or shower base. Im thinking a reinforced rubber maid tub about 40 gallons? How about the bottom of a hard plastic garden tun for a shower base? Hit me with some ideas. Thanks Smitty500
smitty500 is offline   Reply With Quote
Old 01-30-2009, 09:28 AM   #2
Re: Building a black water tank and shower base.
the big box stores sell shower base membrane by the foot, on a roll, 5 or 6 ft wide. IIRC it's the same stuff that is used for rubber roofs except it is code rated to passify the building inspectors. either product should work, just use the recommended proceedure to seal any seams and use folded seamless corners wherever possible. make sure to leak test your work before you cover it.
Old 09-07-2009, 07:50 AM   #3
TygerCub's Avatar
Engine: Detroit
Hi guys. I'm not close to building my tanks yet, but remember ReserectionFern's idea of building their own tanks out of plywood reinforced fiberglass . This idea intrigued me so I looked up the method behind that madness and found this site:
http://www.cichlid-forum.com/article..._aquarium3.php.
After reading how this guy did his, the whole idea doesn't look so crazy to me anymore! I really like the idea of being able to customize the tank to fit odd spaces. As long as the floor is sloped to a single corner for draining, I don't see why this couldn't work. No more trying find a space that's "just right" for that pre-made tank.
As for the shower pan, I'm really lovin' the idea of using a mortar mixing tray.
I found one that's 2' x 3' at Lowes that's just about the perfect size. Just add a little reinforcement on the side walls, add a drain, and walla! Cheap shower pan that fits perfectly next to the back door, or next to the kitchen area for ease in plumbing. I'll probably add a curved curtain rod to the top to give a little more room to move, but with the curtain pulled to the side, the walkway would open back up again.
Just my two cents worth...
Old 09-09-2009, 05:49 PM   #4
newbusser's Avatar
Year: 90
Engine: Navistar Straight 6 Turbo
lovin that idea of making my own tanks. i like working with fiberglass, so will have to give this some more thought.
I will be using plastic 55gallon drums for fresh water, but this would be great for gray and black.
Twenty years from now you will be more disappointed by the
things that you didn't do than by the ones you did do. So throw off
the bowlines. Sail away from the safe harbor. Catch the trade winds
in your sails. Explore. Dream. Discover." Mark Twain
newbusser is offline   Reply With Quote
Need thru tank fittings!! for black water tanks ddpartybus Conversion General Discussions 5 04-18-2015 03:56 PM
Fuel tank for black water bluebird90 Conversion General Discussions 13 04-14-2011 08:21 PM
Fresh, grey, and black water tank size. what do you have? Jerry Campbell Plumbing, Water and Waste 3 10-31-2008 10:56 AM
Black water/ Gray water tank travlenhippie Plumbing, Water and Waste 3 10-21-2008 09:53 PM
black water tank and a door sportyrick Classifieds | Buy, Sell, Swap 16 04-20-2008 12:39 AM
