Old 04-20-2016, 09:47 AM   #1
Chassis: Ford E350
Engine: 7.3L Diesel
Rated Cap: Whatever I make it. :D
Bumper Outdoor Kitchen?
Okay, my 12 year old had a fantastic idea. We literally just got this bus yesterday. It's a fiberglass 28' diesel shuttle.
Pulled it into the driveway and he looks at the back and says, "instead of putting the kitchen inside, what about making a fold down box and putting the kitchen outside. Then we could have a table that slides out from there and have a place to sit food out." Kitchen being Coleman stove and sink. I've been eyeing those fish cleaning stations for $50 anyway and doing a foot pedal sink.
It does have a tow package, so we want to keep that available. I'm searching on Pinterest but don't see anything yet. Has anyone come across anything like this? I need to take a closer look at how the frame goes into the back of the vehicle.
Kim_in_Indiana is offline   Reply With Quote
Old 04-20-2016, 10:32 AM   #2
Rated Cap: Your mom +1
Not a bad idea, but where do you cook if the rain is blowing in sideways or its 10 degrees outside?
Old 04-20-2016, 10:45 AM   #3
I want to do the same thing when I finally buy my bus. My neighbor just bought a new tow behind rv and it has an outdoor cooking station. A door flips down on the side of the trailer and has the cook top and counter space on it. There is a short length of propane hose that is part of it too. When you want to use it you undo the latch and drop the door down so it becomes the cook station/counter. You then connect the hose to a propane connector that is located under the trailer and tied into the propane line feeding the inside stove and heater. You can then light the burner and cook away.
When it is in the closed position it sits flush against the trailer body. The awning covers the area to keep the sun/rain off. There is also a bracket to bring the TV outside to hang on the side of the trailer if you want, and a 110V outlet and cable connector to hook it up. Pretty neat....simple but effective.
dgorila1 is offline   Reply With Quote
Old 04-20-2016, 11:02 AM   #4
skoolie_n00bie's Avatar
Coachwork: Ward
Engine: Navistar 5.9 Diesel
Rated Cap: A butt-load...
$$$ vs practical
....Kitchen being Coleman stove and sink. I've been eyeing those fish cleaning stations for $50 anyway and doing a foot pedal sink....
this is what i'll be using:
table/cleaning station - http://amzn.com/B006JEDPHQ
cooktop - http://amzn.com/B00005OU9D (coleman )
as for the foot pedal, i didn't like what was commercially available, but was very intrigued by this instructable - Field Sink
n00b build > http://www.skoolie.net/forums/f27/th...ily-10122.html
Not my fault if anything I post results in someone losing a finger...
Errare humanum est, perseverare diabolicum
skoolie_n00bie is offline   Reply With Quote
Old 04-20-2016, 11:04 AM   #5
crazycal's Avatar
You need to be pretty coordinated to cook while chasing after the bus.
I'm hungry!
You Gotta Let Me Fly
Old 04-20-2016, 11:53 AM   #6
Robin97396's Avatar
For lack of a better simple option I went with a bilge pump, based on seeing someone else do that years ago. I understand they last about 15 years.
SEAFLO Boat Diaphragm Manual Hand Bilge Pump 720GPH Black
$27.99 & FREE Shipping
Robot Check
This is not the same model I chose but I can't find the one I chose, so...
Old 04-20-2016, 12:06 PM   #7
Docsgsxr's Avatar
Engine: Cat 3126b 250 HP
Rated Cap: Only 1 seat
And fast!!!!!
My build thread - viewtopic.php?f=9&t=467197
Old 04-20-2016, 12:17 PM   #8
Docsgsxr's Avatar
Robot Check
Using that after you make hamburger patties is gonna be a magic trick in itself!
Kim, how about a sink such as.........
You can fill it and drain it outside. May be a bit large, but you could shop for smaller.
And a cook top,
how would that work??
Old 04-20-2016, 12:17 PM   #9
Chassis: Ford E350
Engine: 7.3L Diesel
HAHAHAHHAH! This made me laugh.
That is one way to exercise the kid and keep him away from the tablet for a while.
Old 04-20-2016, 12:18 PM   #10
Chassis: Ford E350
Engine: 7.3L Diesel
Then use the griddle or microwave inside.
