Old 03-24-2016, 07:36 AM   #1
Bus Door
I have been a long time follower of Skoolie and now have my own bus conversion almost done. I remember one of the conversions changed the door of their bus so that it was welded and opened outward. they also put a handle and deadbolt on. Can anyone help me with which conversion that was? I can't do welding so will need a local welder to help me and he asked to see the pictures. But I just can't remember which conversion it was on this site.
Laurel is offline   Reply With Quote
Old 03-24-2016, 09:23 AM   #2
Or if anyone has a picture of a weld job they did to make the door rigid and how they made it swing outward instead of folding inward. It would be a huge help.
Old 03-24-2016, 10:28 AM   #3
Rated Cap: Your mom +1
Not exactly what you're asking for but if you measure your door frame you may be able to buy a security/storm door from a home improvement store that will fit in there nicely... no welding required.
Old 03-24-2016, 02:46 PM   #4
Thank you. I hadn't thought of that and it might be easier than the weld job.
Old 03-24-2016, 05:31 PM   #5
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
Never thought of the Home Security Door myself. I was leaning more toward Marine Doors (no, not USMC).
Old 03-24-2016, 06:32 PM   #6
Solid bus door here, without welding.
http://www.skoolie.net/forums/f10/on...door-6272.html
"The two most important days in this world are the day you were born, and the day you found out why."
Albert Einstein
Missourileo is offline   Reply With Quote
Old 03-24-2016, 06:45 PM   #7
Jolly Roger's Avatar
Engine: Detroit 8.2
Some have been able to find/salvage RV doors that fit.
Capt. Are you missing the (knee/head knockers) hatchways onboard the boat? They did ask about securing the hatches so a real marine door would keep the marines out for a little while and anyone else would just go through the big front windows no matter how your door is secured.
a good watertight and securable door is needed.
Old 03-24-2016, 06:56 PM   #8
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
I have TWO front doors that open outward. They are NOT bi-fold doors. I was thinking more on the order of Freeman Marine doors. These are custom fit and can be equipped with keylocks and dogs.
Old 03-24-2016, 06:59 PM   #9
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
I rode submarines. There were 6 bulkhead hatches and 4 deck hatches. There were NO knee knockers. Mind you, the hull was 2" thick and the bulkheads weren't much thinner.
Old 03-24-2016, 07:11 PM   #10
Engine: Detroit 8.2
Just messin with you
Mine are the same as yours.
To secure from the outside I made a piece of angle iron and clips bolted to the door that I could drop in place padlock and walk?
The problem with that idea is that once the door was pushed tight enough not to leak the drivers door handle latches so I end up in and out the back door anyway.
So I am in limbo on this issue also (money and time)
Just messing with you capt. I do like your idea.
Trying to stay original on the body except for storage underside and my ideas changed when I started DOT inspections but I understand there point
Old 03-24-2016, 07:52 PM   #11
Would something like this work on your double doors? https://www.inlad.com/copy-of-master...et?page_id=950
Albert Einstein
Old 03-25-2016, 12:40 AM   #12
Chassis: TC2000 RE
Engine: 8.3l Cummins
I'm not sure if this is in your wheelhouse, but I built a new door from square tube and sheet metal. Since I've gotten the windows in it looks and works pretty good (I can still use the air ram to open and close it)
http://www.skoolie.net/forums/f11/th...s-9394-57.html
I plan on using traditional "bear claw" style automotive latches to secure the door.
aaronsb is offline   Reply With Quote
Old 03-26-2016, 04:14 PM   #13
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Missourileo, sorry, but I have WAY TOO MUCH GLASS in those doors to support that type of lock. Right now, I use a length of chain secured by two keyed-alike padlocks. Mind you, if someone truly wanted in there, they'd get in. Locks only keep honest people honest.
Old 03-28-2016, 07:38 AM   #14
I looked up your link for the security doors. It looks like they are screen doors. Did you replace the screen with Plexiglas?
Old 03-28-2016, 12:17 PM   #15
Engine: Cat 3126e
Rated Cap: 28
That's the truth.
Josiahdr is offline   Reply With Quote
Old 03-28-2016, 12:59 PM   #16
Robin97396's Avatar
You can always booby trap your place if you don't forget about it yourself.
Old 03-28-2016, 01:00 PM   #17
That could get messy in a hurry. (I am a blond)
Old 03-28-2016, 01:00 PM   #18
that was what I was looking for. Thanks so much.
Old 03-28-2016, 01:02 PM   #19
[QUOTE=slaughridge85;140355]Not exactly what you're asking for but if you measure your door frame you may be able to buy a security/storm door from a home improvement store that will fit in there nicely... no welding required.
IDid you replace the screen with glass? I looked up your link and it looks like screen is behind the iron. I really like this idea though. Thanks
Old 03-28-2016, 04:24 PM   #20
[QUOTE=Laurel;140864]
No it is a security door with removable security glass, it has a screen that you could put up during nice weather though...
Here is the exact model we got...
http://www.menards.com/main/doors-wi...74196142339189
