Old 11-19-2017, 11:04 AM   #1
Chassis: 3000
Engine: 7.6 L / DT466
Rated Cap: 72 Pass.
Bus isnít starting :(
Hey!
I know you have better things to do than help someone figure out why their bus isnít starting but I would really love some advice!
So I removed the air door assembly, unnecessary lights, emergency door buzzer on back and stop sign.
The engine doesnít turn over. I turn the key, fan runs, light beeping noise, then when I turn it all the way to the right it just shuts off. The batteries are good.
What might this be? Maybe it wonít start because I took of the buzzer on the back door or something else.
TheRoanBus is offline   Reply With Quote
Old 11-19-2017, 11:40 AM   #2
Defjr333's Avatar
Chassis: Shuttle or Shorty. Still hunting
Engine: Prefer Diesel
Rated Cap: 14 to 24 pref
I dont know much about the full size skoolies, as I am doing a shuttle, but i have seen this question/ issue in this forum a few times over the past year. I would bet if you listed you make/ model/ year, somebody here can tell you exactly what is causing the no start. I have seen a few unhook something at that door and cause buzzing and no starts. Some kind of safety (the door isnt closed dummy) type sensor/ switch. sorry couldnt help more. But i think those were mostly the rear emergency door....? If nobody replies, you could always try to put back what you unhooked, and try starting till you find the issue. I know nobody wants to Undo work.
Doug
Defjr333 is offline   Reply With Quote
Old 11-19-2017, 11:47 AM   #3
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
Yeah, there are safety interlocks. These buses are made to be safety first. You will have to do a search for safety interlock as there is a solenoid to defeat to get ignition power back.
Old 11-19-2017, 02:57 PM   #4
bigskypc50's Avatar
Engine: DT466 Turbo
Rated Cap: 70
I would start by putting the stop sign and buzzer back in and then try it yes also post who made your bus body a 97 DT466 Bluebird or Amtran
bigskypc50 is offline   Reply With Quote
Old 11-19-2017, 03:20 PM   #5
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
Info on your specific make and model would help,getting rid of the stop sign is a must.
I already assume your back door wiring is the problem.
Why get rid of it? It is there for yours and others safety
During my build I used my bus for Boy Scouts and almost more often than not the door wasn't latched properly and I always forgot to check before I turned the key.
My dummy buzzer didn't tell me where but it did tell me that something wasn't secured properly.
Old 11-20-2017, 08:01 AM   #6
Chassis: 3000
Rated Cap: 72 Pass.
Hey guys thanks for the replies!
It’s a international 1997 dt466 (7.6L) 72 passenger. I think it may be the door.
