Old 04-13-2008, 02:34 PM   #1
1993bluebird's Avatar
Chassis: ALL AMERICAN
Engine: 3116 cat / AT 545
Rated Cap: 48
bus windows
I have a 1993 bluebird tc-2000 bus and I want to change the windows and do that without spending alot of money. can someone help me.
1993bluebird is offline   Reply With Quote
Old 04-13-2008, 05:10 PM   #2
phillbus914's Avatar
Re: bus windows
I have the same bus, the windows are very easy to take out. There's 4 big phillips head screws on the inside of the window frame, take those out, and carefully pry at the top and bottom of the window, and it will come out - they're caulked in all around. Once you've got one out measure the opening and look for a replacement.
If you're looking for RV style windows I've heard you can find deals on ebay or RV salvage yards, try to find one with the same height as your opening, if it's wider you can cut out a support to make it fit.
good luck.
My Old Bus :(
Old 07-30-2008, 09:22 PM   #3
GoneCamping's Avatar
Re: bus windows
If you are looking for RV style windows at a really reasonable price, ebay seller Tri-State Surplus has a whole lot of them... I can highly recommend this particular seller, I've bought from them on 15-18 seperate transactions, they are great sellers, fast shipping, and the best prices you'll find anywhere!!
*Cliff*
...Your home has brake lights
1994 Jeep Grand Cherokee
Chesapeake, Virginia
GoneCamping is offline   Reply With Quote
windows Zephod_beeblebrox2 Conversion General Discussions 8 12-07-2014 10:33 PM
Screening original windows and installing RV windows skoolz out Conversion Tutorials and How-to's 3 10-27-2010 02:54 PM
need help with windows!!! newbusser Conversion Tutorials and How-to's 12 04-01-2010 09:17 AM
Windows TygerCub Conversion General Discussions 15 10-14-2009 11:49 AM
How Many Windows To Tin Over? CVanDamme Conversion General Discussions 3 12-14-2006 08:02 PM
