Old 06-16-2004, 12:33 PM   #1
Steve's Avatar
Campsite Arrival and Departure Checklists
Campsite Arrival Checklist
Place blocks under landing gear.
Plug in electrical cord.
Hook up water hose and pressure regulator.
Hook up sewer hose.
Set up rear stabilizer jacks.
Lower awning.
Raise TV antenna
Set out chairs, grill, etc.
Campsite Departure Checklist
Check tire pressure.
Check oil and fluid levels.
Roll up awning.
Dump black holding tank. (Public Dumping sites)
Rinse black holding tank.
Dump gray holding tank.
Disconnect, rinse & stow sewer hose & coupler.
Unplug & stow power cord, adapters & surge protector.
Disconnect fresh water hose.
Fill fresh water tank (if necessary).
Drain & stow fresh water hose.
Drain & stow water filters.
Disconnect, drain & stow utility water hose.
Turn off propane.
Stow leveling/stabilizing gear.
Remove & stow wheel chocks.
Walk around site to check for forgotten items.
Lock outside compartments.
Lower TV antenna.
Stow appliances.
Close roof vents.
Close all windows.
Secure cabinets, drawers, fridge.
Furnace turned off.
Water heater turned off.
Water pump turned off.
Old 06-17-2004, 08:56 PM   #2
Okay, I'll bite (and when you tell me, I'll say, heck, I knew that)
What is a kingpin stabilizer?
Thanks.
PRyberg is offline   Reply With Quote
Old 06-18-2004, 08:20 AM   #3
It’s a tripod-type unit that you stick up under the over-hang on a 5th wheel travel trailer …it attaches to the kingpin there and helps keeps the trailer from jiggling around a lot when you’re moving about inside.
Are you questioning my Aaa-thoritttyy ?
soused moose is offline   Reply With Quote
Old 06-18-2004, 10:03 AM   #4
Steve's Avatar
http://www.campingworld.com/browse/s...m?skunum=20307
You of course only need it if you made a fifth wheel skoolie (which several people have) and where pulling a trailer.
-> A Huge Tail Gate and Departure Angle SlowMotion Conversion General Discussions 12 04-27-2009 08:52 AM
Boarding up at a campsite Steve Conversion General Discussions 9 12-30-2003 11:49 PM
