06-20-2019, 11:03 AM
#21
Traveling
Year: None
Coachwork: None
Chassis: None
Engine: None
Rated Cap: None
Originally Posted by Joe45
Now, what did that picture ever do to you?
Seriously, that looks a job for a drill. I don't see any other way to get that out. If you're not replacing what was attached to it, should be able to just use another rivet to reinstall if desired.
06-20-2019, 11:23 AM
#22
Originally Posted by bus-bro
To me, that looks like a rivnut put in the perforated metal. From the picture I can't see that it's connected to the bus itself. What I'm trying to say is that you might not have to remove it to take down the perforated ceiling metal, if that's what you're trying to do.
It goes through the perforated metal and into a steel part of the bus. It's in there really solid.
06-20-2019, 11:24 AM
#23
Tried a drill. The anchor thing just spins. Zero effect on it.
06-20-2019, 12:00 PM
#24
Traveling
Year: None
Coachwork: None
Chassis: None
Engine: None
Rated Cap: None
All of them? Or did you just try one? One or more may be broken from removing what attached to it. Could try cutting them out if that's the case... Blowtorch maybe?
06-20-2019, 12:05 PM
#25
Maybe try an angle grinder equipped with a flap wheel? Grind it down flush with the ceiling and bob's your uncle.
06-20-2019, 12:08 PM
#26
Eek!
If you’re not keeping the skin, can’t you just shave them off with an angle grinder?
06-20-2019, 12:11 PM
#27
Chassis: IH 3800, 8 window
May've gotten lost in all the traffic, so again I'll ask: why not hole saw @ the boogers, drop the ceiling, and attack with a sawzall.
My two cents, twice...
06-20-2019, 12:16 PM
#28
Glad you re-posted because I missed the first time. That's a great idea!
06-20-2019, 12:25 PM
#29
That is PRECISELY what I just thought of moments ago. We must have The Force aligned! (not 'the force' from the new, SJW quasi star wars, but The Force from the real Star Wars!)
06-20-2019, 12:27 PM
#30
Originally Posted by Danjo
Eek!
I think I have four options:
- Angle grinder with flap wheel.
- Hole Cutter.
- Air Chisel.
- Det-Cord
06-20-2019, 12:39 PM
#31
- Hole Cutter.
- Air Chisel.
- Det-Cord
I like the hole saw idea
06-20-2019, 12:55 PM
#32
Can I change my vote to det-cord?
06-20-2019, 01:09 PM
#33
I didn't realize you didn't care about damaging the panels, if that's the case I would have used a grinder wheel on an angle grinder and been done yesterday.
06-20-2019, 01:43 PM
#34
How do you stop the pilot bit from turning the nutcert which I guess happened with trying to drill them out? If the pilot bit can't drill thru, then no way the hole saw stays centered.
06-20-2019, 01:50 PM
#35
Just drill right next to it
06-20-2019, 02:29 PM
#36
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
C4 ? .....................
06-20-2019, 02:34 PM
#37
Chassis: TC RE
Engine: 8.3L
Yes, yes, yes!!!
GaryC
06-20-2019, 02:35 PM
#38
Need some? When my brother passed away in Calif., I went out to help clear out the house. This was one memento I brought back. My brother was an Art Director in Hollywood and this was a prop from a movie. I was just a bit anxious bringing this in my carry-on bag at the airport.
06-20-2019, 02:46 PM
#39
Traveling
Year: None
Coachwork: None
Chassis: None
Engine: None
Rated Cap: None
Originally Posted by Gustav
Yes, yes, yes!!!
That's what *SHE* said... *snickers*
06-20-2019, 03:12 PM
#40
Sadly, that was when I asked her if I should leave now...
