Old 06-20-2019, 03:29 PM   #41
Traveling
Year: None
Coachwork: None
Chassis: None
Engine: None
Rated Cap: None
Originally Posted by HazMatt View Post
Sadly, that was when I asked her if I should leave now...
*grins*
Name:	Beavis And Butthead - Hardwood.jpg
Old 06-27-2019, 05:50 PM   #42
Chassis: ThomasBuilt 30'
Rated Cap: me + 1
Originally Posted by Joe45 View Post
I think I have four options:
  1. Angle grinder with flap wheel.
  2. Hole Cutter.
  3. Air Chisel.
  4. Det-Cord
5. Demo Hammer
Old 06-27-2019, 08:13 PM   #43
Chassis: Ford B700
Engine: 5.9, Spicer-5
Rated Cap: 44 Big butts/66 Lil ones
When drilling hard material, get the best bit you can find, use lots of pressure (all you can muster) and real slow drill speed. I find the same tactic works at the metal lathe ( I am no expert, just a self taught backward machinist! ) If I encounter some hard metal that just heats up and destroys my lathe bits, I just slow the lathe down and increase the feed pressure and that same workpiece will cut like butter.
one_eyed_jack is offline   Reply With Quote
Old 06-27-2019, 08:15 PM   #44
HazMatt's Avatar
Chassis: IH 3800, 8 window
Cooling and lubrication of the bit ought not be overlooked, either.
Old 06-27-2019, 08:24 PM   #45
Chassis: Ford B700
Yes, that too.
Old 06-27-2019, 08:26 PM   #46
Traveling
Year: None
Coachwork: None
Chassis: None
Engine: None
Rated Cap: None
Huh, huh... Huh, huh...
Name:	Butt-Head - You Said.png
Old 06-27-2019, 09:15 PM   #47
HazMatt's Avatar
The boy simply ain't right...
Old 06-27-2019, 09:38 PM   #48
Traveling
Year: None
Coachwork: None
Chassis: None
Engine: None
Rated Cap: None
But I ain't wrong, either. LOL
Old 06-28-2019, 05:44 AM   #49
HazMatt's Avatar
Nor did I imply so. Just Cap'n Obvious stepping up to the plate! [emoji41]
Old 06-28-2019, 02:00 PM   #50
So, I’m pretty sure I know the fastener type. They’re used on some light bar kits for off roaring to run wires through the body of the truck without causing leaks. It’s sort of a deformation fastener, I forget the name to.
Hollow, using a special tool to flare the inside and punch itself into place. Then (on the light kits) there is a tap to cut threads to bolt to (or in the case of an LED light bar, a hollow bolt that lets wires pass through)
I forget the fastener name type though. So you may have to drill with a bit slightly larger than the threaded hole itself. Much like drilling out a rivet
Tecchie is offline   Reply With Quote
Old 06-28-2019, 05:04 PM   #51
Joe45's Avatar
Originally Posted by BlackJohn View Post
How do you stop the pilot bit from turning the nutcert which I guess happened with trying to drill them out? If the pilot bit can't drill thru, then no way the hole saw stays centered.
The bit was just the right size. Some of the anchors started spinning just before the hole cutter part touched the metal, so I just angled/wobbled the drill carefully until it caught.
Carefully that is, the second time around. The first try I broke a bit, then bent the other.
Joe45 is offline   Reply With Quote
Old 06-28-2019, 05:42 PM   #52
HazMatt's Avatar
It's Friday night, so I intend to do some angled wobbling myself, after indulging in imbibing a wobbly pop, or few...
