Old 01-05-2017, 09:42 PM   #1
Coachwork: Ford B700
Engine: Detroit Diesel
Thumbs down Changing Tire Size
Please chime in: I have a 98 Ford B700 with 11R22.5 tires/rims... I have an opportunity to pick up some 24.5 Chrome rimes with brand new tires at a steal of a price, Will i have any issues changing the size of rims/tires
Thanks in advance for any information.
Charlie Mac and Ellie!
Charlie-Ellie is offline   Reply With Quote
Old 01-05-2017, 09:57 PM   #2
I found an earlier thread with some input, I will have to check to see which type rim i have, I have not checked, My Bus is being picked up Jan 11, I am working offshore until Jan 10th. Just being excited about starting My Conversion... talking to mechanics out here at work a fellow worker has an 18 wheeler with chrome rims 24.5 and Brand New Tires he said I could have for FREE!!! I would Love to be able to use them.
Old 01-05-2017, 11:43 PM   #3
You are changing the drive ratios by changing the tire diameter, so your speedo will be a little off but otherwise not much difference if you can get them to fit I guess.
There is a calculator online that you can input tire sizes and it will give you the difference in speed etc.
deftone is offline   Reply With Quote
Old 01-06-2017, 12:52 AM   #4
Chassis: IH
Basically you'll have to check 2 things. First, if your bus and the wheels have the same bolt pattern ... 10 lugs is pretty standard. If so ...
You'll need to compare to see if the wheels and your bus are "Hub piloted" or "Stud piloted". The former typically use nuts with a "washer" made into them, the latter use tapered nuts (and a similarly tapered hole in the wheel). No, they are not interchangeable. Over time the stud piloted wheels can begin to crack around the nuts, as it's a pretty small contact area; the hub piloted wheels have a much larger nut-contact surface and are much less likely to do this. It's not a major problem; it is something to be aware of and watch out for.
Old 01-06-2017, 01:52 AM   #5
The 24.5 rims are on an 18 wheeler Truck... If that gives any information without me being on land to actually go check.
Old 01-06-2017, 03:00 AM   #6
Chassis: IH
Buses and trucks both used stud piloted wheels and hub piloted wheels. Typically older vehicles used the stud piloted, newer vehicles use the hub piloted. Pics will help greatly.
Old 01-06-2017, 07:13 AM   #7
Ok, firstly, chrome wheels suck. They rust and flake like you would not believe.
Second, you will have to know the actual tire size numbers to know the diameter of the new ones. A low profile 24.5 is available and common to run. So you may not change any ratios worth mentioning if the 24.5s are really close to the same diameter as your 11R22.5s, which are a good solid tire and on the tall side of the 22.5 wheel.
As mentioned, you'll need to know stud pilot (budd) or hub pilot wheel mounting style. They do not interchange. Hub pilot which is what 99% of all newer rigs will be, you put both wheels on the hub and use one set of 10 nuts to hold both wheels an.
BUDD, or stud pilot, you put the inner wheel on and install 10 double sides long nuts called "thimbles" to hold it on. Tighten the thimbles. Then install the outer wheel and use 10 large diameter budd nuts to hold it on.
The budd style has gone out of favor, and though they are still serviced and will be for some time, they will get harder and harder to service as time wears on.
I like free stuff as well as the next guy, but new tires for free? I would be careful to check the date codes on the tires. The tires may very well be unsafe. Can not tell until you see them and get some detailed info.
A 285/75R24.5 is close in diameter to most 11R22.5s. If however the 24.5s are 11R24.5, you'll end up with a speedometer error of enough to get you a ticket without correction.
Deezl Smoke is offline   Reply With Quote
Old 01-06-2017, 02:18 PM   #8
REDD's Avatar
Coachwork: Thomsass
Chassis: FreightShaker
Engine: 5.9 Cummins 5 speed
Rated Cap: 2 ATV's and friends
Are they actually chrome or polished aluminum that look chrome?
An aluminum alloy rim will be a lot thicker and you may have to change the studs to longer ones....
Old 01-07-2017, 10:30 AM   #9
roach711's Avatar
Rated Cap: 19
The width of the new tires can be an issue too. Wider tires may rub together and wear through sidewalls quickly.
The Roach Motel
Old 01-07-2017, 10:58 AM   #10
For that price... Snap them up!
If you can't use them, Someone on here can...
I'd drive down and haul a u-haul back from Louisiana if they fit mine.
Just sayin'
