Old 05-10-2012, 05:00 PM   #1
Chassis: gmc
Engine: diesel
Rated Cap: 20
Changing to to Super Single Drive Tires
Hi
New to forum and School Bus.. My 1998 Carpenter Cadet 26 pass bus just arrived. We plan to convert it into a rolling advertising base for our Ecommerce Sites
It will be converted from a mild mannered School bus to a "Zombie Hunter" Bus - Black with wire caged windows. Sim fire Machine guns etc.
Our first goal is to give the bus a more of a Road Warrior look - IE: larger off road looking tires. So question:
Any one have any experience changing rear duallies into Super Single rear drive tires. -- Not real worried about GVW capabilities.
Bus presently has 19.5 x 6 wheels. AS soon as I figure out the bolt patterns can begin searching for replacement wheels and tire combos.
gruemeyer is offline   Reply With Quote
Old 05-11-2012, 10:43 AM   #2
Re: Changing to to Super Single Drive Tires
weld up some spear things to bolt to your rear axle hubs.... so when you drive by someone you dont like you can pull into them a bit and slice open their door...
Old 05-11-2012, 02:00 PM   #3
TheRainbowBoxer's Avatar
Engine: 5.9 Cummins 12v
Rated Cap: 78 Passenger
You should put the bus body on a m35 (deuce and a half) frame. That would fit the theme!
(plus I've wanted to see someone do that for a while now!)
-Dan
"What's the matter Col Sanders? Chicken?" -Dark Helmet
lu·di·crous [loo-di-kruhs]
adjective
causing laughter because of absurdity; provoking or deserving derision; ridiculous; laughable
viewtopic.php?f=9&t=11840
TheRainbowBoxer is offline   Reply With Quote
Old 05-21-2012, 02:58 PM   #4
Chassis: gmc
Engine: diesel
Rated Cap: 20
Funny you should mention a 6x6 we are bidding on one now.... Will be a new project..
Old 05-21-2012, 03:00 PM   #5
Chassis: gmc
Engine: diesel
Rated Cap: 20
Thanks for suggestion.. Any others would be accepted -- We thought about 22 or 22.5 wheels.. unfortunately this would require a 6- 8 " lift.. ( Way scarey on turns)
Old 05-23-2012, 09:02 PM   #6
Chassis: gmc
Engine: diesel
Rated Cap: 20
Well moving on -- The 6 x 6 idea has taken toot.. I am putting the Bus up for sale tomorrow and already bidding on a 6x6 with Van, shop, tool cap on back..
changing tires w/o a jack tylermag Conversion Tutorials and How-to's 6 08-04-2013 08:05 PM
4 drive tires jazty Classifieds | Buy, Sell, Swap 1 04-24-2013 06:57 AM
Big single cylinder motorcycle engine? Elliot Naess Everything Else | General Skoolie Discussions 62 04-12-2010 03:33 PM
Steer Tires vs. All-Position Tires arfisher83 Everything Else | General Skoolie Discussions 1 06-09-2009 09:59 PM
Single most costly. reprobate Everything Else | General Skoolie Discussions 16 05-15-2008 11:54 PM
