Old 07-13-2018, 12:13 AM   #201
gypsyfiredance's Avatar
Originally Posted by Tango View Post
Thank goodness those are cats. I first thought you had nine monkeys.
OMG...I laughed so hard on this one.
gypsyfiredance is offline   Reply With Quote
Old 07-13-2018, 07:08 AM   #202
Brewerbob's Avatar
Originally Posted by cwol97401 View Post
My class A RV is 8'6" out, 8'0" inside. Wide Bodies are the exception, not the rule. Bet on 7'6"
Yours started life as a Class A or is a converted motor coach? Just wondering if there's a difference between the class A and Greyhound.
Old 07-14-2018, 12:50 PM   #203
Yeah mine started as a class A. I haven't the property to build out a skoolie yet so I'm biding my time and live full time in a store bought coach
cwol97401 is offline   Reply With Quote
Old 07-22-2018, 03:23 PM   #204
One of the ideas we are playing with.
navonifamily is offline   Reply With Quote
Old 07-22-2018, 05:18 PM   #205
Here's what I'm working with. Decided to cut 6" out of the garage to accommodate more room up front. My bus is only 37', I'd like to have that extra window and 3' for build out, but wouldn't want to hauling that extra 3'. this think is big enough.
Old 07-23-2018, 07:19 AM   #206
Brewerbob's Avatar
I hope so. That 3' would have kept your 6" in the garage. I just hope I don't run into too many places that don't allow 40'+.
Old 08-01-2018, 03:50 AM   #207
mikeypj's Avatar
Engine: 9.L
Rated Cap: 64
Ive spent 3-4yrs drawing up floor plans. But since im just getting my bus i feel as if better ideas will happen when we are stripping it out. Im not going to build with out a plan, but i feel right now those hundreds of floor plans are not going to work in real life.
mikeypj is offline   Reply With Quote
Old 08-25-2018, 07:46 AM   #208
Chassis: Chevrolet G30 Short Bus
Engine: 5.7L chevrolet 350
Originally Posted by gypsyfiredance View Post
What a great idea!
I plan to do the same thing. 3-D cardboard gives a real feel for
what you have.
rewou812 is offline   Reply With Quote
Old 08-25-2018, 06:48 PM   #209
Chassis: B8000
Rated Cap: 24
All of you newbies need to change your priorities . First Get a bus. Try to get one that runs and every thing WORKS on it. Throw in a bed , cooler, Porta-pottie and some camping gear (coleman stove , Lantern and such . Take a week long trip. Longer if you can swing it. If you come back in love with it then by all means go for it. Remember you cant have every thing in a bus that will fit in a house. You can have every thing you need. Do Not spend five years planning and building . If I was healthy enough to build another one and travel I would be doing it not talking about it. I built my first one in 1975 in a 66 pas. 11 rows of seats, GMC With a 305 cu In. v6 gas moto and a4 speed Stick. I lived in it 8 years from Ca. to Fl. following Welding jobs. I loved it! I kicked my own a-- for selling it to save a failing marriage . I should have paid someone to take her. Now I use a short Ford Thomas F8000 for a daily driver because iv'e been in a wheelchair 11 years. I had Travel Trailers Boats and Harleys in between. but I still miss that GMC. My point is Do Not waste your healthy years trying to have SHOW bus. Get out there and DO IT. Keep the shiny side up!
reedy is offline   Reply With Quote
Old 10-22-2018, 05:26 AM   #210
Setsu-P's Avatar
I know, I know, obtain a bus first.
But I wanted to have something concrete to look at on paper for now. No measurements yet, I'll get on that next.
Living area separated from driver zone, because cats will be involved and I don't want one to hang out underfoot up there.
Pass through window behind the driver for the cushy copilot chair. Dutch door. The wall by the stairs will be thick enough for a recess with a flip down panel, to store the DVD player, router, and anything else too tempting not to try and steal.
(I'm in security, crimes of opportunity are everywhere)
Focussing more on work space here because we both craft and do art business. Galley type kitchen as neither of us are chefs =p
Seating area and the copilot space will be raised up over the wheelwells, with a storage drawer underneath for fabric.
Yes, that is a kotatsu. I built it so it is definitely coming with me. It'll be hinged so it can be raised against the wall if someone needs to sleep over. We can just lay out the futon mattress.
Wavy lines will be curtains (high enough off the floor to reduce cat temptation). I'm going for a more open floor plan if I can manage it.
Depending on the location of the side exit the kitchen/bath and workspaces can be switched. You're supposed to keep plumbing all on the same side anyway, aren't you?
I'd like to build the beds out from the engine hump in the back if possible and use the hump itself as a table, but I don't know the dimensions of those. Anyone who's had a Thomas RE happen to know that measurement offhand?
Setsu-P is offline   Reply With Quote
Old 10-22-2018, 10:20 AM   #211
Brewerbob's Avatar
[QUOTE=Setsu-P;295512]Wavy lines will be curtains (high enough off the floor to reduce cat temptation). Unless you have legless cats, I'm guessing your curtains will only be 2 or 3 inches long!!
Nope, but if you want the measurements from a Blue Bird, I can help you out.
Old 10-22-2018, 09:51 PM   #212
Setsu-P's Avatar
I'm going off of mine's behavior where it comes to venetian blinds. Raising the blinds up about 6" made them stop trying to paw the things out of the way so they could smear their little faces all over the window. Presumably a curtain will work the same way. In my experience, if you give them easy access, they're less likely to make trouble for the sake of attention. Or, mine are just lazy =p
best laid plans, right?
If the engine hump is the same size, that'd be perfect; at least it's something to go off of!
for the reply!
Old 10-23-2018, 08:24 AM   #213
Brewerbob's Avatar
Ah, ok. You're fine then. I was thinking they were climbers. Mine being 20 lbs each don't do a lot of climbing. They do the same as yours. My house has really deep window sills and they prefer to have the window open as well. They are fat enough they bent one of the curtain rods by sitting on the curtain.
for the reply!
<-- :Shrug: really needs to be added. I've no idea if it is different or not. I've never measured a Thomas.
So here's what I have. The * on the 19 1/2" is because I don't remember if the bench is 19 1/2" deep with or without the triangle.
Old 10-23-2018, 01:01 PM   #214
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
I have a 2003 Saf-T-Liner (RE Transit style). Inside dimensions approx 30' long from engine to line, and 7.5' side to side.
Old 10-23-2018, 01:12 PM   #215
Brewerbob's Avatar
From profile:Rated Cap: 84 passenger
I smell fishes!!!My Blue Bird is also 84 pax. 40'2" bumper to bumper. It's approx 34' from the back of the driver's seat to the rear glass. 30' would be about right from seat to the start of the engine cover. Is that what you mean from "engine to line"?
Old 10-24-2018, 10:12 PM   #216
Setsu-P's Avatar
Y'all are true princes among people!
one more question since I'm fleshing my floor plan out as a scale model (if you're feeling generous), how tall is that Thomas from bottom to top without accounting for the wheels?
Old 10-25-2018, 06:15 AM   #217
Brewerbob's Avatar
Best as I know Thomas and B.B. come in two heights 74" and 78" with 74" being the most common.
Caveat: I think mine is 74" with the plywood removed. I ripped all of the flooring out as well as the sheet metal ceiling and if I stand up straight, my head touches the ribs. I'm 6' 1 1/2"~2". With shoes (not boots) I still touch.
So, I chopped off the roof and raised it about 18". Still need to take a final measurement. Now standing flat footed I can just reach the ribs!!
Old 10-25-2018, 10:07 PM   #218
Setsu-P's Avatar
Thanks again!
What is it, an inch, inch and a half between interior and exterior skin? Same for the difference between edges and center, or is that more like 2" on the inside?
Yeeaaah, I don't think my budget will allow for a roof-raisin'. But then I'm only 5'7" and my roommate is like 5 and change. Supertall visitors will just have to stoop and bear it =p
78" would probably be the city-transit bus ceiling height, I'm guessing. Not sure if I'm in the market for one of those since I believe they have even less ground clearance than the school models. I may or may not be dealing with bad-road PTSD after living where I am for five years.
Side note, I think I ran across your video while going down the YT bus conversion rabbit hole a while back. Love the humor
Old 10-26-2018, 01:23 AM   #219
bus-bro's Avatar
Engine: 3208 na boat anchor
My Bluebird must be a 74 inch one. With 1 inch polystyrene and 3/4 inch plywood on the floor I can walk through with an inch or two to spare. That's with my shoes on -- then I be 6 foot tall!
Old 10-29-2018, 06:26 AM   #220
Brewerbob's Avatar
Thanks again!
So, the ribs of the windows look like this.
No need then tho the extra space would help with cabinets and the like. 74" and 78" is in the center (not at the windows).
No, I'm told the skoolies come in a 78" height. Motor coaches and city transits are altogether different.
Skoolies come in two flavors; conventional; (dog-nosed) and transit (flat nose). Transit is not to be confused with city buses.
Cool, thx. I've got a couple and a bunch of bits and pieces that I still need to edit into another.
Bus Rib.jpg   IMG_20171108_082623.jpg   IMG_20171108_082637.jpg   IMG_20171108_082615.jpg
Looking for Floor Plans Belchfire Conversion General Discussions 3 12-06-2014 06:45 AM
Floor plans Skip Conversion General Discussions 5 12-31-2013 08:07 PM
Floor plans Please? Telestar Conversion General Discussions 7 04-06-2005 11:45 AM
