Old 06-05-2017, 06:50 PM   #101
Engine: Diesel
Rated Cap: 71
Originally Posted by Brewerbob View Post
You should probably reconsider if you are near bear county.
You know, once I hit Colorado, I think I WILL take the food off the sides. Great idea! ;)
DawnTreader is offline   Reply With Quote
Old 06-05-2017, 06:52 PM   #102
Engine: Diesel
Rated Cap: 71
Originally Posted by Robin97396 View Post
Sounds like a solid well thought out plan. Some people put tape on the floor to outline where things are intended to go.
We want to solidify our plans that way after removing the seats and flooring. I think our measurements will be by the window, rather than by the foot.
Old 06-05-2017, 08:18 PM   #103
tobeamiss's Avatar
Measuring by window is the way I'm going too... starting with the bedroom, then I'll be putting closets and storage over the wheel wells.... And I'll just keep working my way up to the front. I'm going by window because I don't want to halfway block any of them. When I first got the seats out I used masking tape and got a general idea. Then I decided where I wanted the shower to go and worked around that. So, I basically know what I want, now let's see if I can make it happen 😃👍
Sent from my SM-T350 using Tapatalk
oh yes she did!
https://www.skoolie.net/forums/f11/to...-it-16557.html
Old 06-05-2017, 08:30 PM   #104
Brewerbob's Avatar
Might sound silly but make sure all your windows are the same. Mine (and a lot of other Blue Birds at least) are NOT the same. I have 25 inch and 32 inch. Not even all the emergency windows are the same. The emergency door is in a 25 inch row as well.
Old 06-06-2017, 05:15 AM   #105
tobeamiss's Avatar
The very first window on the driver and passenger sides are both a couple of inches larger from the rest. Otherwise all of them are 27". I think the first Windows are 31".
oh yes she did!
Old 06-27-2017, 09:16 AM   #106
Hobotang's Avatar
Rated Cap: 83
Anyone using an mobile app to create floor plans? I've dabbled in a Sketchup, but I think the learning curve will be too much for me.
https://www.amelia-bartlett.com/the-skoolie/
Hobotang is offline   Reply With Quote
Old 06-27-2017, 10:45 AM   #107
Brewerbob's Avatar
Hate it with a passion. Even after watching the videos online. I used Visio. NO idea if they have a phone app tho. It will convert to damn near anything tho.
Old 06-27-2017, 10:46 AM   #108
Hobotang's Avatar
Rated Cap: 83
I'll check it out, thanks Bob!
Old 06-27-2017, 11:28 AM   #109
Njsurf73's Avatar
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
I used Faber-castle #2
Couldn't find a free version of versacad and I haven't used any other cad program since the 90s
Old 06-27-2017, 12:25 PM   #110
Hobotang's Avatar
Rated Cap: 83
[emoji23][emoji23]
Analog looks like it's my best bet [emoji23][emoji108]
Old 06-27-2017, 12:32 PM   #111
Brewerbob's Avatar
Old 06-27-2017, 12:33 PM   #112
Njsurf73's Avatar
Chassis: Bluebird
Rated Cap: 72 pax
All joking aside... I searched online and found some grid paper that were 40 long.
I measured the floor, and poof. I have a 35' bus with 29 usable at the floor and a couple more where the engine cover is in the back. I plan on the bed being headboard towards the driver's side... The old "seat" (engine cover) becoming a cabinet and laid out about 10 different iteration using just the blocks.
My final has the shower and toilet on the driver's side, the kitchen sink as well... All plumbing directly over the gray and black tanks. Still leaves plenty of room for a lounging area (in case of rain) just behind the cockpit
Old 07-02-2017, 09:24 PM   #113
Just getting started
This thread goes back to 2004!!!
Had to jump in on this one. In the early planning stages for a Thomas or Blue-Bird conversion. No idea when I can pick up a bus but wanted to work on SOMETHING, so I created a floor plan.
Let me know if you have any suggestions or advice.
davehearn is offline   Reply With Quote
Old 07-05-2017, 07:51 AM   #114
Brewerbob's Avatar
How much driving are you going to do? There's no co-pilot.
Not much in the way of storage. Aside from that, I like it.
What did you draw it in?
Old 07-05-2017, 11:39 PM   #115
Thanks!
My plan is to do a considerable amount of driving but I'm pretty solitary. No wife or girlfriend (confirmed bachelor) I do have two kids but I would be driving in any case. I've though about adding a co-pilot seat and moving the door. Putting the co-pilot on a swivel so it can double as a chair for the table. Again, these plans are extremely temporary.
As for storage, I'm working up a side-elevation for the interior to help figure out storage. Right now, I know there will be cabinets above the worksurfaces in the kitchen, some storage under the bed, hopefully more storage under the sofa. Any suggestions would be greatly appreciated.
I'm working in iDesign on my iPad. Once you figure out the interface, it's a pretty intuitive program.
Old 07-05-2017, 11:52 PM   #116
How do you like that Blue-Bird, Bob?
Old 07-06-2017, 06:45 AM   #117
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
Adobe Illustrator template 35' Bluebird FE TC2000
So, it's getting time to layout my build and I made this nifty Adobe Illustrator CS6 template- I thought others might like this tool. Use and enjoy.
Illustrator is wrong tool and does not like to be accurate, but can be forced. Everything is scaled so 1 pixel equals an inch- don't change that. Draw a cabinet 24 pixels by 12 pixels and its 2 feet by 1 foot.
Pixels are small, but Illustrator works in vectors, which are scalable without degradation. Use navigator to see details of your drawing on screen. When it comes time to print, don't change size of drawing, use print and scale print by 150% or whatever to fill paper.
There are rulers and grids to help see floor spacing. Layers utilized to reduce clutter on screen.
This is first iteration, so in infancy yet. If you add furniture or components, share them and this template can grow.
Download Illustrator template tool
JPG of layout
Oh yeah, my bus is only 35 feet long, not 40'- which is a good thing for Nat'l Parks, bad for layout. More storage and details to come.
Old 07-06-2017, 04:36 PM   #118
Noob here gathering loads of information about Skoolie's and life on the road. Do national parks/national park campgrounds have vehicle length limitations or something? Could you provide me with a website for additional information?
Thanks!
jetjr is offline   Reply With Quote
Old 07-07-2017, 07:08 AM   #119
Brewerbob's Avatar
Love it so far. But I would go for a MD3060 Allison tranny over an AT643. Two overdrive gears if you can get Allison to unlock the second.
If you are NOT doing a roof raise, take a look at the Thomas buses. Their walls slant inward from just below the windows. You can roof raise them below the windows but now you have a single break line with you cut the bus. The advantage is all of the ceiling panels are screws instead of rivets. I don't remember what Thomas has for drive line options other than Cats which are said to be expensive.
Old 07-07-2017, 07:13 AM   #120
Brewerbob's Avatar
Thanks!
I've heard the same. No idea if there's any truth to it. I doubt there's a hard fast rule that applies to every park. Some roads, some camper spots, etc sure. But no 40 footers? Phfft. The coaches are as much as 45 feet.
Looking for Floor Plans Belchfire Conversion General Discussions 3 12-06-2014 06:45 AM
Floor plans Skip Conversion General Discussions 5 12-31-2013 08:07 PM
Floor plans Please? Telestar Conversion General Discussions 7 04-06-2005 11:45 AM
