Old 02-23-2016, 05:46 AM   #1
Coolant filling
How do u top off the coolant in a blue bird bus front engine? I popped off the case/grill but I can't seem to uncapped the coolant. Any videos? Bit of an emergency
carneiro1292 is offline   Reply With Quote
Old 02-23-2016, 05:47 AM   #2
Coolant
How do u uncapped the coolant cover in a flat nose front engine blue bird?
Old 02-23-2016, 08:48 AM   #3
2kool4skool's Avatar
Careful when hot, use a rag to cover the cap, unscrew the cap slowly. As you turn (lefty loosy) the cap, it stops at partial open, push in slightly and it will rotate until it releases. The res. should have some coolant in it, if you can see it, it's ok.
If low fill until it reaches the lip of the res opening.
Don, Mary and Spooky the cat.
Old 02-27-2016, 12:46 AM   #4
yea i just didnt realise you had to squeeze and really put some pressure and turn, i was afriad i was gonna break the cap and be stuck in the middle of bum F%*& no where at 4 in the a.m. with 2% life on the phone. someone eventually came by 40 min later and helped out. thx anyways guys
